While idling if your step on the gas and it seems to hesitate before reving up, it's an air intake leak usually the curved intake boot. You won't be able to see the hole until you take it out and flex it.1989240sx wrote:...the car was shaking real bad and sounded differently...
Had the same issue, same solution... Infact same injector went, I'd check compression if I were you. My head gasket blew a week after i put the new injector in1989240sx wrote:okay guys i did so work on my car and it is a bad injector i test it by disconnecting one injector at a time to see it there was any changes in the car when i did the first one there was no change at all so where is the best place to buy new injector
