loyalone wrote:
i don't have the tools to do a compression check yet, but it doesn't burn or leak any oil at all.
so i was looking at a water leak this thing has and it's coming from a block heater, does every nissan have a block heater on it or is it after market? i don't see why anybody would need it cause it starts just fine in 14 degree weather.
for a moment i was worried you had a diesel and were throwing regular fuel in it cause diesel motors usually have block heaters because the ignition temp of diesel is higher than that of gasoline because it is less volatile so in colder areas up north and in every firetuck in the USA block heaters are used to aid in easier faster starts the first time every time. but you wouldnt have a diesel cause you don't got glow plugs but ive heard if you put diesel in a gasoline truck it can in lower concentrations prevent proper power from being transfered to the road and in high enough concentrations seize a block but thats all useless info i think for your problem...What kinda person/persons have owned this rig sometimes people abuse things and your rig might be one of em. Talking to people about trucks ive learned that the general concensus is that "Our" trucks are fun lil throw-a-way trucks that are ment to be harped on and trashed cause they were "cheap" then thrown in a junk yard i would ditch that hitachi tho that things exploded diagram was scary i think a ford engine has less to it than those things
See if this helps anyone can use it if you want hopefully they dont get pissed but go
http://www.alldata.com login under User:Takko1988 PW Time2500 its the everything you could need for a 1986.5 nissan HB it might not have the carb in there cause the 86.5 is a EFI but it lists stuff for older models too
Also Ive been reading about other vehicles that had similar problems that you are having one such incidence was a part of the inner wall of the exhaust pipe just after the flange of the bottom of the manifold had broken loose and slipped to one side blocking off half of if not more of his exhaust which prevented him from accelerating hard prevented the timing from retarding but he was still able to reach high speed if he slowly accelerated, the other problem that seemed to be a re-occurring in other vehicles 1) don't use seafoam or anything like that to clean blocks it messes with sensors 2) some people where having problems with their distributors or the shaft inside the motor being rotated 180 degrees off. I thought i was having that problem for a time but i discovered that my input shaft off the dist was a semi circle and could only go on one way but the year before had a full circle with a rectangle taken out of the center which could allow for it to be put in backwards which could change the firing order of your cylinders. But even if thats not the case keep on it its gotta be either fuel spark vacuum or timing just be meticulous in everything its real gay to spend a bunch of money for something you missed in step 2 oh and if you think this is a bunch of reading it took me 45 min to read what these poor bastards had to go through just cause they're mechanics at Midas missed the problem 2 times while replacing cats and mufflers on this guys blazer in the first two posts he listed.
Modified by Takko1988 at 1:56 AM 2/22/2010
Modified by Takko1988 at 3:13 AM 2/22/2010
