Q45tech »
https://forums.nicoclub.com/q45tech-u112.html
Fri Sep 22, 2006 4:40 am
To generate the same HorsePower E85 must flow at 25% higher rate therefore you wll get 25% LOWER MPG vs conventional gasoline [without oxygenates].
Even ethanolized [10%] gasoline will consume 3-4% more fuel per mile than non oxygenated.
The secret is that ethanol has a high RON value and a lower MON value than the MTBE it replaced in oxygenated gasoline so the same OCTANE PUMP LABEL NUMBER may be functionally INFERIOR to the old MTBE blend.
High compression engines may react badly to ethanolized gasoline depending on the exact MON value the engine needs?
Keeping the plugs, valve stems, and piston crowns clean of deposits is critical [even more critical the higher the ethanol percentages].
