PEZi wrote:danshaz82 wrote:all the grounds i took off are all back on and everything is back they way it should be (i believe).
i also have seen people talk about a plastic insulator on the back of the alt. im not exactly sure what that is or where it goes.
Check these in as much depth as possible. It has something to do with what you did when you re-wired it, it wouldn't just start doing this because you put in a new starter.
there were only 2 grounds that i actually removed. i looked at the one that goes to the block right next to the intake mani, and there was a little bit of wire exposed. i gotta tape it up tomorrow or something.
allenms240 wrote:You're in luck, I did this yesterday. What I did was removed that terminal line and took off that plastic clip to get more room on the terminal for the bolt. I put the harness (the ground looking one, but really it's the one that goes from the alternator to the battery, charging it.), bolted it up, and blew the fuse. You can actually ghetto rig the fuses to work again instead of blowing your good one, just take the plastic cover off the fuse, and push the broken pieces together.
Anyways, It's blowing because you DONT have that plastic clip, the lead IS NOT supposed to be touching the alternator as you mentioned it is. When you do that, it will pop the fuse. You need to find that plastic cap, or a plastic washer so that when you bolt the lead onto the alternator, the harness is only touching the terminal and NOT the alternator. Please ask questions if you have any, I'm sure I can answer them, I just did this yesterday lol.
Allen
this is exactly what i wanted to hear
ill have to see if i still have the old one. but the terminal that the ground goes over broke, so there is little room. there should be enough for a thin washer tho. if not, would i be able to move it to another spot on the alt?
