lsajsa »
https://forums.nicoclub.com/lsajsa-u243530.html
Fri Oct 31, 2014 3:37 am
I ran across your post as i was trying to repair my daughters 2008 Altima with the same problem as yours, except the shift nob removal wasn't the cause of the issues.( she told me it just happened monday?) now that i recall when i got the call she said the shifter would not move. so i did remove the safety shift lock.
i pulled the trim off first and then i pull of the hole center console and put the shift nob back and drove it around for a day and it drove fine, the transmission works perfect
and the auto shift.
I changed the bake light switch at the brake pedal, no luck, brake lights are fine i check all the fuses.
i know its been a long time but did they ever tell you what they did to repair the issue.
if you remember of course. thx
