have a late FS5W71B that is really noisy in neutral at idle
- loud gnashing and growling noises - noises go away when clutch is depressed, but can also be heard when coasting in 1st-2nd with clutch out; there were no shifting problems; T.O. brg is perfect
I have studied the manual section from the database - concluded it was an internal problem, and begun dis-assembly
i have removed both housing sections and have the center plate mounted on vise with a home-made adapter
all the "end" bearings that mount in the housings are butter smooth and not noisy, gears all perfect, baulk rings look fine
- nothing obvious as a potential source of all the noise
- can't tell about the center bearings yet, and i have to check all the clearances before i start taking it all apart
but before i do that, does anyone have some ideas based on your experience as to what i should be looking for and expecting to find???
curiously, i had this box installed a few yrs ago & it was not noisy when i pulled it out back then - it's been in dry storage ever since, standing on its nose
all advice & tips appreciated, including links to other threads on this, as well as best parts sources
TIA
