Man, I knew I had read this somewhere, and I can't figure out why this seems so wrong, but....
I am now driving the 1992 Nissan Maxima GXE that I inherited from my folks after totaling my Y33 '99 Q45T, and after they bought a '07 M35. The problem I have is this:
Since I was already a member here at NICO, I started researching the current car to see what I could do with it (mainly because of the OEM 17s from the Y33 that I wanted to put on the Max). Well, I ran into this page:
http://www.maximaclub.org/previous.shtml
Quote »3rd Generation Maxima (1989 - 1994)
The third generation received a complete upgrade. The boxy look was scrapped for an new aerodynamically shaped model. The SOHC V6 was kept, but upgraded to release 160hp. The GXE only came with a 4-speed automatic, while the SE model had an optional 5sp manual. 4-wheel disk brakes were standard with optional ABS. GXE also had the optional Sonar-monitored Suspension that adjusts shock-absorber damping automatically, and a helpful heads-up instrument display. In 1992, a new 190hp DOHC V6 (VE30DE) was offered in the SE model (hence the definition change to 4DSC for "4-door Sports Car") while both had optional drivers-side airbags and ABS. [/quote]The part about the brakes makes me leery - because I was present when the car was bought (in June of '92, and yes it is a '92) and it has rear drums, not 4 wheel discs, and thus (I think) does not have ABS (which is optional, but hey, no biggie).
The bigger problem is that I told my insurance company this and they turned around and re-wrote my policy after researching the car and said I *did* have ABS on the car.
So, that leads me to 2 questions:
1) Does the fact that I have drums on the back make my car somewhat funky, or could you still order a 3rd gen as late as '92 without discs in the rear?
2) Will I be liable if the car's brakes lock up and I have a resultant accident, since *the insurance company* made the change and added ABS on the car policy after I specifically told them I did not have ABS?
