350z/G35 Rear camber arms installed on 3.5 Altima SEDAN
General discussion area for the L31-chassis Altima, including the 05-06 SE-R models.
acidjake75
Car: 05 DB Z
Had to get the this fixed ASAP - saw that altima camber kits come with just bolts and took the plunge and bought some decent camber arms for the Z and sure enough - fit like a glove. Did the toe bolts and camber arms and got an alignment and now Im all back in the GREEN.. woo-hoo!
Camber wear - this is ONLY 3 mos gents...they go QUICK!
Side by side - OEM vs SPC Adjustable (you can see you have ALOT of room to play with as far as adjustment goes)
Installed with some lockout washers since all the adjustment is done at the arm and not those dumb eccentric washers! :naughty:
Bought an expensive 20 dollar bit for my dremel...this is before
This is about 10 mins after - so worth EVERY PENNY :woot:
There you have it - 350z/G35 Camber arms installed on an altima (2005 sedan) :dblthumb:
Im sure the coupe is the EXACT same.. ;)
SlateSER1788
Car: 2005 Nissan Altima SER
I see in your sig you have H&R's. Did the springs lower your car that much to throw off your camber to where you had to get adjustable arms? I'm definitely interested in this and would like to install them on my SER but I saw the tire wear and thought maybe you had coilovers and needed the camber arms to get a level camber.
acidjake75
Car: 05 DB Z
^^^my sig is for my Z holmes...My girls Altima Sedan is dropped on an eibach Pro Kit.
Regardless - just being dropped on springs made the camber that much different... I would do the camber arms if I more than a 1 inch drop..
tismo74
Car: Altima 2.5
Thanks Jake for this valuable info. :bigthumb:
acidjake75
Car: 05 DB Z
No problem tismo74 - figured it was better than cutting into your subframe...hoping others will see this and take advantage.
98blackbell
Car: 1995 Nissan 240SX SR20DET(STOLEN)
1993 Nissan 300ZX 2+2
2006 G35 Coupe
1998 Chevy Tahoe 2DR 5.7
1975 Datsun 260Z Turbo
You got pics of the car with the pro kit on it.
I have Raceline and the front is too low!
acidjake75
Car: 05 DB Z
Prokit looks great..specially with G35 coupe rims...
I dont have any pics of the drop - but will get some when I get home..
BLACKonBLACK98
Car: Q45, LS400, STS-V
i can't see the difference between the before and after with the bit. what exactly had to be done?
acidjake75
Car: 05 DB Z
^^^If you look closely - first pic is just marker (I used the template and marked it with a sharpie) and in the second pic - its actually widened after using a dremel so that you can have that "extra" adjustment you need..
BLACKonBLACK98
i see it now. cool. any thoughts on using spl toe arms with the adjustable spring cup?
acidjake75
Car: 05 DB Z
dont see why not - they are fully adjustable so it should be golden...
Return to “3rd Generation Altima Sedan (2002-2006)”
