350Z Diagnostic ECU Codes and How to Clear Them
Troubleshooting, DIY's, How-To's and articles about all Nissan vehicles. Non-vehicle specific "General" How-To and tech information is also here.
Clearing Codes on the G35 and 350ZThere are several ways to clear ECU error codes.
- Scan ToolIf using a scan tool, follow tool manufacturer’s instructions to clear Codes.
- Manual MethodHere is a quick way to reset your ECU. It is also known to clear codes thrown, and turn off the "Service Engine Soon" Light.
Confirm that accelerator pedal is fully released, turn ignition switch “ON” and wait 3 seconds. Repeat the following two procedures quickly five times within 5 seconds: Fully depress the accelerator pedal (HARD). Fully release the accelerator pedal. Wait 7 seconds, fully depress the accelerator pedal and keep it for approx. 10 seconds until the CEL starts blinking. Fully release the accelerator pedal (while the CEL is still blinking) Wait about 10 seconds. Fully depress the accelerator pedal and keep it for more than 10 seconds. Fully release the accelerator pedal (The CEL light will continue to blink). Turn ignition switch to “OFF” position and now you can start the car. The CEL light should be gone.
- With Consult
Turn ignition Off. Connect Consult’the data link connector (DLC), located behind fuse box cover. Turn ignition On. Touch Start. Touch Engine. Perform each diagnostic test mode according to each service procedure.
- Without ConsultTurn ignition On. Turn diagnostic mode selector on ECU fully clockwise and wait until inspection lamps flash. #Number of flashes displayed indicates corresponding mode. Note number of flashes, then immediately turn diagnostic mode selector fully counterclockwise. If ignition is turned Off during diagnosis, in each mode, and then turned back on again after power to the ECU has dropped off completely, diagnosis will automatically return to Mode I. For description of modes, proceed as follows:
(Mode I): with engine stopped, system in bulb check state. with engine running, system in malfunction warning state.
(Mode II): with engine stopped, system in self diagnostic results state. with engine running, system in front O2S monitor state.
- CodesP0000 No Self Diagnostic Failure Indicated P0011 Intake Valve Timing Control P0021 Intake Valve Timing Control P0031 O2 Sensor Heather P0032 O2 Sensor Heather P0037 O2 Sensor Heather P0038 O2 Sensor Heather P0043 O2 Sensor Heather P0044 O2 Sensor Heather P0051 O2 Sensor Heather P0052 O2 Sensor Heather P0057 O2 Sensor Heather P0058 O2 Sensor Heather P0100 MAF (Mass Air Flow) Sensor P0101 MAF Sensor P0102 MAF Sensor P0103 MAF Sensor P0105 Absolute Pressure Sensor P0107 Absolute Pressure Sensor P0108 Absolute Pressure Sensor P0110 IAT (Intake Air Temperature) Sensor P0112 IAT Sensor P0113 IAT Sensor P0115 ECT (Engine Coolant Temperature) Sensor P0117 ECT Sensor P0118 ECT Sensor P0120 TP (Throttle Position) Sensor P0121 TP Sensor P0122 TP Sensor P0123 TP Sensor P0125 ECT Sensor P0127 Intake Air Temperature Sensor P0128 Thermostat Function P0130 Closed Loop, Bank 1 Or Front O2S, Bank 1 P0131 Front O2 Sensor, Bank 1 Lean Shift Monitoring P0132 Front O2 Sensor, Bank 1 Rich Shift Monitoring P0133 Front O2 Sensor, Bank 1 Response Monitoring P0134 Front O2 Sensor, Bank 1 High Voltage P0135 Front HO2S Heater, Bank 1 P0136 Rear O2S, Bank 1 P0137 Rear O2S, Bank 1 Minimum Voltage Monitoring P0138 Rear O2S, Bank 1 Maximum Voltage Monitoring P0139 Rear O2S, Bank 1 Response Monitoring P0140 Rear O2S, Bank 1 High Voltage P0141 Rear H02S Heater, Bank 1 P0144 O2 Sensor Heather P0150 Closed Loop, Bank 2 Or Front O2S, Bank 2 P0151 Front O2 Sensor, Bank 2 Lean Shift Monitoring P0152 Front O2 Sensor, Bank 2 Rich Shift Monitoring P0153 Front O2 Sensor, Bank 2 Response Monitoring P0154 Front O2 Sensor, Bank 2 High Voltage P0155 Front HO2S Heater, Bank 2 P0156 Rear H02S Sensor, LH Bank P0157 Rear O2S, Bank 2 P0158 Rear O2S, Bank 2 P0159 Rear O2S, Bank 2 P0160 Rear O2S, Bank 2 P0161 Rear H02S Heater, LH Bank Or Bank 2 P0171 Fuel System Lean, Bank 1 P0172 Fuel System Rich, Bank 1 P0174 Fuel System Lean, Bank 2 P0175 Fuel System Rich, Bank 2 P0180 Tank Fuel Temp Sensor P0182 Fuel Tank Temperature Sensor P0183 Fuel Tank Temperature Sensor P0217 Engine Coolant High Temperature Enrichment Protection P0221 Throttle Position Sensor P0222 Throttle Position Sensor P0223 Throttle Position Sensor P0226 Accelerator Pedal Position Sensor P0227 Accelerator Pedal Position Sensor P0228 Accelerator Pedal Position Sensor P0245 Supercharger Bypass Valve Control Solenoid Valve P0300 Random Misfire P0301–*P0308 Misfire, Cylinder No. 1–8 P0325 Knock Sensor, Bank 1 P0327 Knock Sensor P0328 Knock Sensor P0330 Knock Sensor, Bank 2 P0335 CKP (Crank Shaft Position) Sensor P0340 CMP (Cam Shaft Position) Sensor (Phase) P0345 CMP Sensor (Phase) P0350 Ignition Signal P0400 EGR System P0402 EGRC/BPT Valve P0403 EGR Volume Control Valve Circuit P0405 EGR Temperature Sensor P0406 EGR Temperature Sensor P0420 TW (Two-Way) Catalyst System, Bank 1 P0430 TW Catalyst System, Bank 2 P0440 EVAP Small Leak P0441 EVAP Control System Purge Flow Monitor P0442 EVAP Control System P0443 Purge Control/V & S/V P0444 EVAP Canister Purge Volume Control Solenoid Valve P0445 EVAP Canister Purge Volume Control Solenoid Valve P0447 EVAP Canister Vent Control Valve P0450 EVAP Pressure Sensor P0451 EVAP System Pressure Sensor P0452 EVAP System Pressure Sensor P0453 EVAP System Pressure Sensor P0455 EVAP Control System P0456 EVAP Control System P0460 Fuel Level Sensor Unit (Slow) P0461 Fuel Level Sensor Function P0462 Fuel Level Sensor P0463 Fuel Level Sensor P0464 Fuel Level Sensor Circuit P0500 Vehicle Speed Sensor P0505 IACV/AAC Valve P0506 Idle Speed Control System P0507 Idle Speed Control System P0510 Closed TP Sensor P0550 Power Steering Pressure Sensor P0600 A/T Comm Line P0605 ECM/ECU P0650 Malfunction Indicator Lamp P0705 PNP Or Inhibitor Switch P0710 ATF Temp Sensor P0720 VSS A/T P0725 Engine Speed Signal P0731 A/T 1ST Signal P0732 A/T 2ND Signal P0733 A/T 3RD Signal P0734 A/T 4TH Signal Or TCC P0740 TCC SV Solenoid P0744 A/T TCC Signal P0745 Line Pressure S/V P0750 Shift Solenoid/V A P0755 Shift Solenoid/V B P1031 Air/Fuel Ratio Sensor Meter P1032 Air/Fuel Ratio Sensor Meter P1065 ECM Power Supply Heater P1102 Mass Air Flow Sensor Function Heater P1103 MAP Sensor Heater P1104 MAP Sensor Heater P1105 MAP/BARO Switch SOL/V P1108 MAP Sensor Heater P1110 Intake Valve Timing Control, LH Bank P1111 Intake Valve Timing Control Solenoid Valve P1119 Radiator Temperature Sensor Circuit P1120 TP Sensor 2 P1121 Electronic Throttle Control Actuator P1122 Electronic Throttle Control Actuator P1124 Throttle Control Motor Relay P1125 Tandem TP Sensor P1126 Throttle Control Motor Relay P1128 Throttle Control Motor P1130 Swirl Control Valve Control Solenoid Valve P1131 Swirl Control Solenoid Valve P1132 Swirl Control Valve P1135 Intake Valve Timing Control, RH Bank 2 P1136 Intake Valve Timing Control Solenoid Valve P1137 Swirl Control Valve Position Sensor P1138 Swirl Control Valve P1140 Intake Valve Timing Control Position Sensor, LH Bank 1 P1143 Heated O2 Sensor 1 P1144 Heated O2 Sensor 1 P1145 Intake Valve Timing Control Position Sensor, RH Bank 2 P1146 Heated O2 Sensor 2 P1147 Heated O2 Sensor 2 P1148 Closed Loop, Bank 1 P1163 Heated O2 Sensor 1 P1164 Heated O2 Sensor 1 P1165 Swirl Control Valve Control Vacuum Check Switch P1166 Heated O2 Sensor 2 P1167 Heated O2 Sensor 2 P1168 Closed Loop, Bank 2 P1169 Heated O2 Sensor 3 P1170 Heated O2 Sensor 3 P1210 Traction Control Signal Circuit P1211 ABS/TCS Control Unit P1212 ABS/TCS Communication Line P1217 Engine Coolant Temperature P1220 FPCM P1221 Throttle Actuator Circuit P1222 Temperature Sensor Circuit P1223 Throttle Position Sensor 2 P1224 Throttle Position Sensor 2 P1225 Closed Throttle Position Learning P1226 Closed Throttle Position Learning P1227 Accelerator Pedal Position Sensor 2 P1228 Accelerator Pedal Position Sensor 2 P1229 Sensor Power Supply P1271 Air/Fuel Ratio Sensor 1 P1272 Air/Fuel Ratio Sensor 1 P1273 Air/Fuel Ratio Sensor 1 P1274 Air/Fuel Ratio Sensor 1 P1276 Air/Fuel Ratio Sensor 1 P1278 Air/Fuel Ratio Sensor 1 P1279 Air/Fuel Ratio Sensor 1 P1320 Ignition Signal, Primary P1335 CKP Sensor (Ref) P1336 CKP Sensor (POS) Cog P1400 EGRC Solenoid/V P1401 EGR Temp Sensor P1402 EGR System P1440 EVAP Small Leak P1441 VC/V Bypass/V P1443 Canister Control Vacuum Check Switch P1444 Purge Volume Control/V P1445 Purge Volume Control/V P1446 Vent Control Valve P1447 EVAP Purge Flow P1448 Vent Control Valve P1456 EVAP Control System P1464 Fuel Level Sensor Circuit Ground Signal P1480 Fan Control Solenoid Valve Circuit P1490 VC/V Bypass/V P1491 VC Cut/V Bypass/V P1492 Purge Control/V S/V P1493 Purge Control/V & S/V P1564 ASCD Steering Switch P1568 ICC (Intelligent Cruise Control) P1572 ASCD (Automatic Sped Control Device) Brake Switch P1574 ASCD Vehicle Speed Sensor P1605 A/T Diag Comm Line P1610 NATS Malfunction P1611 NATS Malfunction P1612 NATS Malfunction P1613 NATS Malfunction P1614 NATS Malfunction P1615 NATS Malfunction P1705 TP Sensor A/T P1706 PNP Switch P1720 Vehicle Speed Sensor- A/T Output P1760 Overrun Clutch S/V P1775 Torque Converter Clutch Solenoid Valve P1776 Torque Converter Clutch Solenoid Valve P1780 Shift Change Signal P1800 VIAS Control Solenoid Valve P1805 Brake switch P1900 Cooling Fan P2122 Accelerator Pedal Position Sensor P2123 Accelerator Pedal Position Sensor P2127 Accelerator Pedal Position Sensor 2 P2128 Accelerator Pedal Position Sensor 2 P2135 Throttle Position Sensor P2138 Accelerator Pedal Position Sensor
Return to “Nissan Articles”
