well I contacted competition clutch who uses a 350z pressure plate with a 240sx clutch disk on their setup and they use a 240 TOB.GTR PrYdE wrote:Ask whoever sells the kits, SPEC, AMS,
but I would think you'd use the 240's, since it still has to hook up to the stock trans
I bought a rb20 flywheel for 30 bucks used off a guy in town. then I ordered a dxd clutch stage 1 for the 350z for 350 and it can hold 433tq! so my total cost is about 400 bucks(20 for a 240sx TOB).GODCHSR wrote:Help me here...Are you bolting it up without modification? What all did you use?How much Wheel power is that setup expected to hold?
That's pretty dang effective...I wonder what the stock 350z clutch holds.?.?.?kazuma wrote:
it fits without any modification to your car as long as you have the rb20 flywheel.
O....M....F....GGTR PrYdE wrote:That sucks... Have you tried adjusting the clutch master rod? It might be constantly engaged, causing that. Try that before you go pulling the trans
Haha funny thing, we just got back from eating steak for my bro's bday, but I'm glad you got it sorted out!!kazuma wrote:
O....M....F....G
YOU ARE MY LIFE SAVIOR!!!!
I did the adjustment and it fixed it! no more slippage at all!!!!!!
if you were here I'd buy you a nice big a** steak lunch .
Thanks again for your help!
btw the stock 350z clutch holds about 280ft/tq which is a lot for our cars already but for like 50 bucks more you can get the clutch I got from dxd clutch and it handles 433 ft/tq!
ya so far so good, cant rev past 3k yet since the clutch is being broken in but cant wait for the 500 miles to be over so I can get on it a bit .GTR PrYdE wrote:
So this also confirms that a 350z tob will fit the stock trans!
Maybe I'm reading into it too much... Is there another flywheel that will work?kazuma wrote:1.rb20 flywheel(or something exactly like it )
Well I'd think any flywheel that would be compatible with a rb20/rb25/early rb26's would work in this setup as well.GODCHSR wrote:
clutch disc, pressure plate and throw out bearing are from a 350z.mksue3240sx wrote:Did you use the 350z disc, or a 240 disc?
The 350Z plate does bolt to it, however the plate is not a perfect match. You may have to clearance some holes in order to make it fit just perfect.EODguy036 wrote:spec steel flywheel (part #sn42s) is made for a ka and can fit up to a 254mm sr20 clutch acording to they guys at spec. i got that and a spec 350z stage 3 plus clutch kit. havent had the chance to see if the 350z presure plate and clutch fit corectly but the guys at spec asured me that they would. if not ill just send it back and get an rb20 one.
the question i have is will this all match up with my z32 trans when i get to that point, god i hope so.
That is part # SN333-2 which is the 350z 254mm clutch. The only other clutch besides the SN54 series that fits with OUR flywheel is the SN33 series which is the 240mm SR clutch.EODguy036 wrote:so could we fit this 254mm?
http://www.specclutchsuperstor...964a2
not to much more $ if you where going that rought anyway.
