evildky »
https://forums.nicoclub.com/evildky-u13100.html
Tue Jan 12, 2010 10:10 am
you said you checked the cas, how? have you checked the ecu for codes? if no stop what you are doing and check the codes!
the very first step is to check the ecu for codes, they will tell you a lot, in checking the cas you test 2 things, one is the ignition, pull a cop and stick a screwdriver in it and place near a ground, rotate the cas and look for spark, if you have no spark it's either the cas or the ptu, if you have spark then fuel is the likely suspect, while rotating the cas use either a noid light or a lofic probe to determine if the injectors are getting signal, yoiu said you pulled the fuel ose and you didn't specify but it should come out at a high rate if not then the pump or fpcm would be suspect
