G-E »
https://forums.nicoclub.com/g-e-u207983.html
Fri Aug 22, 2014 9:39 am
Ok let's start a list of who's interested, consider this a pre-buy since they are going to be produced anyway...
Intro price will be $260+ship
Installation:
1. cutting strut tube
2. drill a hole in the bottom
3. clean everything thoroughly with acetone or other potent solvent
4. installing the adapter oriented correctly with panelbond or equivalent glue
5. torque bolt with stainless spacer underneath to 150ft-lbs, locktite recommended
Requires:
1. almost any front s13 coilover or other coilover with s13 lower bracket
2. suitable 240Z top hat for coilover (or universal)
*** I will be producing a batch of stepped washers to use s14 brackets on s13 spindles or this adapter for extra cost...
Benefits:
1. will allow up to 9 degrees of camber adjustment depending on coilover bracket
2. doesn't require camber plates
3. has set screw on adapter to mark camber locations for disassembly
4. pre-set screws can be made for quick road or track alignments
5. lightweight aluminum body, stainless lower plate, oversized retaining bolt, approx. 700grams total
6. adds up to 1.5" of backspacing depending on wheel used
7. allows really wide wheels
