240sx white bunny clutch setup
Biggamehit
Car: R33 Skyline
DR30 Skyline
Sil80
180sx
Yup well after more research i went with this setup, i would explain, but ill just show the facts from another buddies setup. I have had a mixture of different clutches over the years ranging from oem to ACT Xtream. i just like to try new things. my current setup with lighten flywheel is failing becuase of Weak Diaphragm.---(taken from 240sxforums 240sxAddict/creator from another forum)
The "White Bunny Special" was first created and explained by s14turbose, the "white bunny" being his 98 S14 turbo SE. KA24's come stock with a 225mm clutch surface area, but using parts from other nissans allows you to run a 240mm clutch, which by logic gives you more tractable area for the clutch to grab onto thus reducing the chance of slippage.
We used the flywheel of a 1993 D21 Pickup(4 cylinder model), which is the standard flywheel to use because it carries the same crank bolt pattern as our cranks but is a 240mm flywheel. I believe any year will work, 87 being a common year people use but to play it safe use the 93 because I just installed one and it fit fine. There is also talk of lightened 240mm flywheels, but I have yet to see any that arent custom made.
Now the pressure plate and clutch disc are varied. We used the stock setup of the afor-mentioned 93 D21, but common clutches used are off the 280Z Turbo, the 300ZX Turbo, and the RB series clutches. You can use both aftermarket and stock as long as it is 240mm. But one rumor surrounding this special is the truck and 280Z clutch can hold balls of torque, some saying near 400ft/lbs and they still retain stock pedal feel and longer life than aftermarket clutches. I'm still searching for the answer, but I read it went on Mike Lee's T66 KAT, and it had no problems holding 500rwhp.
One very important point is that the 240mm clutch uses 9bolts to hold the pressure plate onto the flwheel, while your stock uses 6. Be sure to pick some up before you attempt this. Also, you'll have to break the small pin on the crank off to bolt up the flywheel, as it has no slot for it.
and of course here are the comparision pictures:
this is both setups(225mm and 240mm) set beside each other
example of size difference
Update:installation pictures
White bunny test video
after about 2 cans of brake cleaner still had 2more to goas a result of not running my dust cover this happen. i thought it would help with cooling, but was I wrong..................yupmore size difference picstools used to remove old worn pilot bearing for act bearingputting new setup on
the little bulge that you see at the bottom of the dust cover is what the flywheel will grind down. when the noise has stopped, you will be able to insert your bolts at the bottom of the bell housing. after that, more noise will sound for about 1 minute. after that your all go.
My pictures ( total price $215 dollars)
Modified by Biggamehit at 6:59 PM 2/9/2007
Modified by Biggamehit at 7:36 PM 2/17/2007
Logan76
Car: Junk
Thats awesome, now get on the ball and get it installed so we can get some feedback on if it works better for ya or not.
Biggamehit
Car: R33 Skyline
DR30 Skyline
Sil80
180sx
10-4 bro i just got swamped with work, so i will not have time to install it until next week, i also have to pick up some more Motul gear oil for my tranny.
i was also going to add a staged clutch to the mix which in theory would boost the durability up even more, but gotta be a good boy and pay of debts LOL.
sancosys
Ok Ill try to get pics if you dont. I bought my 240 w/ a slipping clutch and need to change it any way. I Just got home from the parts store and am going to try and do it this weekend. Thanks for the info.
Aaron
daconkiftador
Car: '92 Coupe SE, '83 Rabbit GTi, '91 Golf GTi
awesome, cant wait to hear the results of it being installed!
Bwana
Car: Denali
Bigger = better, proven yet again...
DJButton
Car: 2010 Nissan 240sx
Lookin good! Logic is such a great friend!
Bwana wrote:Bigger = better, proven yet again...
That's what she said!
babowc
Car: 240sx
do it and share how it feels..i've done it in my current car..still in the car,slow revs suck, but im sure with your turbosetup, it shouldnt make much difference..
gotta love the larger friction area tho.
white90esex
Car: 90 240sx
90 Q45
12 Titan Pro4x
06 xB
al that stuff only cost u 215 dollars???!
If so.. thats a hell of a deal for a set up that can handle 500lb/ft torque. ITs bigger, better, and CHEAPER!!!
Biggamehit
Car: R33 Skyline
DR30 Skyline
Sil80
180sx
yes sir, updated with pictures and video
flywheel=71 dollarsclutch kit=134 dollarsact pilot bearing and TO bearing= 10 bucks and some change
ill put this to the test after i break it in. im hitting the dyno, can't wait
Biggamehit
Car: R33 Skyline
DR30 Skyline
Sil80
180sx
Update
well i was able to put all of the miles on the clutch in philly on the way home i really put it to the test.
as you know my wastegate has a 8lbs spring. it was cold on the way back and i think the line slipped off or was punctured. so when i went to test the clutch the car spiked up to 15 psi for a second and the clutch held every damn bit of it. 215 bucks well spent lol
Bwana
Car: Denali
Not quite enough white bunny in this thread...
SAVED!!!
Razi
Car: Moo
Bwana wrote:SAVED!!!
Phew!!
Haha, I'm jealous of you Biggamehit.
Biggamehit
Car: R33 Skyline
DR30 Skyline
Sil80
180sx
Funny bunny LOL
dude
yesterday was cool and bad at the same time.
my original turbo developed a case of shafto play lol so i had an z31 T3 laying around, i put that on the night before the trip, the seals blew on my while in philly. lets just say my bov was spitting oil all over my gotdamn engine bay, it was that bad.
ill have another turbo by this weekend.
mutiny
Car: 1989 240SX
Wonder what the weight differences are between the d21 and stock 225mm flywheel are?
babowc
Car: 240sx
3-4lbs iirc.alot of difference.
the white bunny setup is HEAVY, i didnt it vs stock stuff.
i may just run this again though..can just d21 autozone special hold upto 500ft/lbs of tq?...
ppctx
Car: 93 ka24de-t
This kit comes with everything, is there any reason to buy an act pilot and TO bearings? Will the ones in the kit not work or are acts just better. http://www.autozone.com/R,APP3...l.htm
Kraelic
Car: 89 240sx
I am unable to load that autozone link, however, just guessing you got a flywheel from a truck, a clutch from a 280z, and the crank and transmission are still 240sx? I do not know for sure, but I'd think the throwout bearing and the pilot bushing for a 280z will not work in a 240
Fahaka
Car: '96 S14 '07 Versa
Yeah you would use the KA TB and pilot bushing...
This is funny because the white bunny is now the "Murcielago Pearl Yellow Bunny"
Hah!
corey240
Car: 1993 Nissan 240SX Base Drift Machine
will it work with sr?
Car: 58 L210, 63 Bluebird RHD, 64 NL320, 65 SPL310, 66 411 RHD, 67 WRL411, 68 510 SR20, 75 280Z RB25, 77 620 SR20, 79 B310, 90 S13, 92 SE-R, 92 Silvia Qs, 98 S14.
Mike Lee will be posting his experiences in this thread in a bit....
ppctx
Car: 93 ka24de-t
The description of the item is Clutch Set-Matched. The picture looks like it includes pressure plate, clutch disk, TO and pilot bearings, and that centering thing. I checked what engine came with the early 90 D21 and it was a KA24E, dont know if the transmissions are the same as the 240sx, so still not sure it the TO and pilot bearing can be used from the set. It also makes special note calling is Performance? The part number is 06-901I think they use the same bearings, both vehicles list the same part numbers for them. HA, actually the same part number will pull up for use on the 240 or D21. Luk the manufactures site says its 240mm
http://www.autozone.com/home.htm and pop in the part number
Modified by ppctx at 4:58 PM 7/11/2007
Topless_92
Car: 92 Nissan 240sx Convertible
Today i went over to Nissan to order my clutch and went to Advanced to get my flywheel, and i'm doing this same setup. 240sxAddict is actually my brother and he said its a really nice setup. Also it is pretty good price
Edit: This is "240SXAddict". big, you only used one of my pictures! Haha. And I really dont agree with letting the flywheel grind away at the plate. Shards of metal + clutch = something I don't want to deal with. Our install went into a buddies coupe that didn't have the shield. This setup is perfect for guys with relatively low numbers who want a near stock feel but a clutch that will last them a very long time. But this setup kicks the stock setup's ***. And if you're shooting for bigger numbers, just add an aftermarket clutch kit with a higher stage to the "larger" flywheel
And no, it will only work on the SR20 if you can find a flywheel with the 240mm surface and the correct flywheel "bolt pattern"
Modified by Topless_92 at 8:39 AM 7/12/2007
t66240
Hey guys,
sorry for the late reply. This is Ryan Yap's (white bunny) conception. I was just the first to have it in my car. I made 55X RWHP and 47X RWTQ and i've had very good luck with the clutch. With that said I hardly launched the car but I did plenty of beating on the car once it was moving. Ask anyone who really knows me... I can't stay out of the throttle. I'm currently rebuilding for more power so I got a chance to pull it apart and it looked pretty good. ..... Remember the "real" white bunny had a aluminum flywheel (custom) and a ACT Z32 non-turbo street/strip disk and pressure plate. It was also lighter than stock with that combo. Anyhow I remember Ryan saying the D21 flywheel didn't fit the KA24DE so he had a custom flywheel made... so it might just be on the KA24E that it works?
If this works it looks like a great budget clutch but if I now believe the better solution is a chromoly (lighter and stronger) RB20 flywheel with any aftermarket 350Z clutch.
FWIW,Mike Lee
btw you can use a Z32 TO bearing. It's much stronger.
Modified by t66240 at 4:28 PM 7/12/2007
ppctx
Car: 93 ka24de-t
I found the following info at an online retailer. Only checked the D21 vs 300zx NA, but they list the same part numbers for clutch and flywheel (cant believe the same parts are used in so many vehicles). I guess this could help when shopping the local salvage or part store for "white bunny" parts.
280ZX 78-83 2+2 non-turbo280ZX 1979 2+2 turbo300ZX 84-1/31/89 non-turboPathfinder 86-89 2.4Pickups 2.0 83-89, 2.4 83-12/31/96
Years Make Model Engine Type Liter Size 1987 - 1988 Nissan 200SX V6 3.0000 1975 - 1978 Nissan 280Z 2+2 L6 2.8000 1978 Nissan 280ZX 2+2 L6 2.8000 1980 Nissan 280ZX 2+2 L6 2.8000 1982 - 1983 Nissan 280ZX 2+2 L6 2.8000 1981 Nissan 280ZX 2+2 GL L6 2.8000 1984 - 1989 Nissan 300ZX V6 3.0000 1984 - 1989 Nissan 300ZX 2+2 V6 3.0000 1983 - 1985 Nissan 720 Pickup L4 2.0000 1983 - 1985 Nissan 720 Pickup L4 2.4000 1986 Nissan 720 Pickup L4 2.4000 1986 Nissan D21 Pickup V6 3.0000 1986 - 1994 Nissan D21 Pickup L4 2.4000 1987 - 1989 Nissan Pathfinder L4 2.4000 1994 Nissan Pickup L4 2.4000 1996 Nissan Pickup SE L4 2.4000 1995 Nissan Pickup Short Bed E L4 2.4000 1994 - 1996 Nissan Pickup Short Bed XE L4 2.4000 1994 - 1996 Nissan Pickup XE L4 2.4000
Q: I'm quite positive that most people reading know quite a bit more about this topic than I do, but I've read a crap load of "white bunny" threads and no one has said that the flywheel required modification. There was a mention of a small post needing to be broke off (with minimal force by hand) the housing the flywheel goes into?
dickie
Car: Killer Turtle
neato!
mutiny
Car: 1989 240SX
is it possible to just drill a hole for that notch, or some other flywheel alternative? I don't think I wanna bust off that notch on the crankshaft haha
Bump for Mike...
mutiny
Car: 1989 240SX
AZhitman wrote:Bump for Mike...
yea and so someone can answer my question
ppctx
Car: 93 ka24de-t
I think if you read this http://www.240sxforums.com/for...90222 someone ask the exact question
