240sx trans into hardbody
zil40
Car: 89 240sx
i searched the exact topic title and didn't find answers. i am wondering if a transmission out of an 90 sohc 240sx will bolt up to a 2wd 86 z24 nissan hardbody pu?
Modified by zil40 at 9:05 PM 1/4/2009
ca18datsun510
Car: bmw 330i zhp, 91 infiniti m30, 89 240sx, 07 zx6r, 05 trx450r
it will bolt up to the engine.
but it is longer.
shifter will be pushed back, and driveshaft will have to be shorter.
zil40
Car: 89 240sx
thanks, i thought it bolted up, but wasn't certain about lengths and starter loactions. i didn't have both here to measure.
breadbox
Car: 89 Nissan 240SX
89 Koop
84 720 4x4KC
Whenever you do have both transmissions out and next to each other measure them and take a picture. I really want to get a together sticky and find all the similarities between z24 and ka24. If I ever get a third car I will go to town but not until then.
nismopu
Car: 1987 Nissan 300ZX
1997 Nissan Maxima
1976 Datsun 280Z Turbo
There's very few similarities, IMO between z24 and ka24. They share the same bore and stroke, and similar cam configuration.
The z24 has:an l-series style oil panlarge oil passages in the blockdouble row chainadjustable valves(no lifters)8 valves onlyoval exhaust ports8 spark plugssmaller oil pump
KA24e features:a unique oil pansame oil pump as the l28et(auto)single row timing chainhydraulic lifters12 valves4 spark plugsround exhaust ports
Also, to answer the above question the 240sx transmission will bolt up but you will have to use the 240sx starter. The bolts thread into the starter on the 240sx and into the transmission on the HB. peace.
breadbox
89 Koop
84 720 4x4KC
Wow. Good to know.
Natedawg500
Car: 1997 240sx/ls1 swap
anyone know if the manifolds are the same between the ka24 and the z24. they are about 50 bux cheaper on ebay? and i need one.
nismopu
1997 Nissan Maxima
if by exhaust manifolds yes but it will bolt up to your engine. Just maybe not up to your exhaust. The napz has oval ports and the ka's have round ports,but the bolt patterns are the same. peace.
ca18datsun510
240 trans is the longer one.
slammedhardbody
Car: nissan hardbody
will tha hardbody bell housing bolt up to tha 240 transmission?
ca18datsun510
the bellhousing is the same.
mike_belben
keeping with the theme of this thread, im wondering about bellhousing pattern on the FWD altima KA24DE blocks vs the RWD car and truck blocks? im new to nissan and looking at making some adapters to other trannies. im told rotation is the same on all of them. what about starter location, flywheel thickness and so forth?
could the FWD and RWD engines be interchanged between their respective transmission out of the car and on the bench? engine compartment constraints not being considered.
ca18datsun510
why?
s13_240_rb20
Car: 1990 240sx RB20DET
This question also seems relevant here:
Is there any difference in the "yoke" for a s13 240sx driveshaft and the "yoke" for a 1993 Hardbody??
(I know the RB20's transmission will work with the s13 240sx driveshaft, but I need to make sure the RB20 transmission is also going to fit the "yoke" on the Hardbody driveshaft)
Almost identical motors and transmissions in the s13 and hardbody...someone please tell me if the "yokes" are the same??
--TJ
breadbox
89 Koop
84 720 4x4KC
I don't have my 240sx driveshaft in I could measure it
Do you want over all length or minus the part that sits in the trans?
ca18datsun510
the transmissions are not almost identical, the truck one is way shorter.
the truck shaft will slide into the rb20 trans, but it doesnt matter, the driveshaft will be way to long.
s13_240_rb20
ca18datsun510 wrote:the truck shaft will slide into the rb20 trans, but it doesnt matter, the driveshaft will be way to long.
thanks,
mitch89
Car: 1989 s13 240sx
quick question, i am getting an 87 hardbody 4x4 can i put my 89 240sx engine it in, being that it is 4x4, and if so, can i fanagle my transmission in to the truck as well?
