Articles, modifications, maintenance, DIY's, how-to's and general information for 240sx owners.
DIY: Replacing Your Rusted Hatch
Postby fiznat » Wed Jul 23, 2003 9:25 pm
So after an exhausting search for a nice spoiler-less (and more importantly rust-less) hatch to replace my messed up one, I finally found one this morning. A trip to a not-so-local junkyard and $100 later, I had one in my driveway, ready to install.
I saw that there were some people who had trouble replacing their hatch (mostly with the wiring), so I figured why not take pics while my friend and I did it and make a cool little DIY for NICO.
Here it goes.... Please try not to post anything till I'm done, I'll letcha know when I am!
Step One: Locate the hatch:
Yep. There it is. Good job.
fiznat
Car: S13 240sx x 2
Step Two: Remove the paneling inside
The panels are held in by two bolts pointed out here, both are hidden under little black caps that you can pop out with a flathead screwdriver.
Underneath there you'll get a much better understanding of how the wiring works, and you'll understand why we had to do what we did next:
fiznat
Car: S13 240sx x 2
Step Three: Cut The Wires
Now, I've heard a lot of talk about finding a clip and re-attaching wires without having to do any real splicing or soldering, but honestly that seemed like an impossible dream. A quick snip with a pair of linesman's pliers and the hatch was halfway off.
To be honest though, we did sorta end up cursing ourselves for doing this later on. Due to the short length of the wire and the tight working spaces, cutting the wires at this point makes it very hard to work on. If you decide to take this route, CUT THE WIRES AS CLOSE AS YOU CAN TO THE OLD HATCH! Even pull them out as much as you can if possible... I'd even reccomend cutting them off of the rear defrost points and pulling them through, if you can. Honestly, it'll save you alot of trouble. Also before you do any wire cutting make sure you disconnect the battery from the car... dont want anybody shocking or shorting things now do we?
NOTE: If you cant tell from the pictures, this is the left side of the hatch- the wires here (there are 2) are associated with the rear defrost. There is a similiar looking setup on the right side of the hatch in the same place, but there are many more wires there- all of them are associated with the brake light and rear wiper motor. More about that later.
fiznat
Car: S13 240sx x 2
Step Four: Look At The Wiper Wires
Inside the hatch there is a little carpeting cover that can be taken off very easially by undoing all of the little clips holding them in. To take those off, just get a small screwdriver and press IN the middle part, and then you can just pry them right out. It really is pretty easy.
Once you have that up, take a look at the wires on the right side of the hatch (you may have to take a razor and cut off the black electrical tape surrounding them).
One look at these and you'll know that it's gonna be WAY too hard to try and cut this wire way up where the hatch meets the roof and attempt to splice the wires there. What we decided to do is to KEEP THE OLD WIRING ON THE RIGHT SIDE OF THE HATCH. Just cut them as close as you can to their respective ends, so that the wire will come down from inside the car, through the hatch, and end right there under that carpet thing you just pulled off. A better pic of this is coming in a sec.
fiznat
Car: S13 240sx x 2
Step Five: Unbolt And Take Off The Hatch
The hatch itself is held in by 4 (13mm if I remember right?) bolts that are right at the top of the glass.
Since you already have the panels off on both sides of the hatch inside the car, just pull down the headliner a little bit and you can see the nuts right there ready to be unbolted. Be Careful when you do this, cause this (and the lifters) really are the only thing holding your hatch up: it'll fall down once you take these out.
Once it's unbolted, pop the lifters off on the hatch end (they just wiggle right off these round-headed studs), and take that nasty old thing off of your car. Note, though, that the wires on the right side of the hatch are probably still in there, so be careful pulling them out... They stick a little bit sometimes, but they'll come out if you're nice to em.
fiznat
Car: S13 240sx x 2
Step Six: Take A Step Back
Yep. Take a step back and look at what you've done.
The wires my friend are holding up are the ones on the right side of the hatch (brake light/wiper). Note how they are all original and intact, cut ONLY AT THE VERY END, with PLENTY OF SPACE for splicing into your new hatch!
Also, since you're taking a step back, put the hatches next to eachother and marvel at how much better your newer one looks. HA HA in your face, rusty hatch!
fiznat
Car: S13 240sx x 2
Step Seven: Pull The Wires Through Your New Hatch
Okay, it's a little hard to understand just looking at the picture, but what we did was attach the old wires (where we cut them) to what we could see of the new wires. The "new" wires were cut by the junkyard, and about 2 inches were hanging out of the end of the hatch.
Just take the two ends (the TOP part of the new wires and the BOTTOM part of the new ones) and tape them together really well. Make sure you intertwine the wires and tape them together really well.
When that's done, take off the carpet from the inside of the new hatch just like you did with your old one, find the right-side wires, and PULL them through towards you. They will come all the way out, and, pulling with them, the old wires that are still attached to the inside of your car.
When you have it pulled all the way through, undo the tape that you put together before, and VIOLA, you've got the right side of your hatch halfway done, without having to work in that cramped space up in the top or having to mess with those rubber gromets up there! Wooo!
Cut the wires on your new hatch off of the wiper motor and brake light, making sure to leave some space to splice them into the old wires you just threaded through.
To finish up the right side (sorry I dont have a picture of this), just pull the insulation off of the ends of each wire and connect them to the wiper motor and brake light wires (the ends you left extra) with some 14-16 gauge butt connectors. This sounds hard, but it's actually really easy-- if you've ever worked on stereo equipment it's the same deal. Just make sure you dont have any bare bits of wire showing and do a good job clamping down the butt connectors so they dont come undone.
fiznat
Car: S13 240sx x 2
Step Eight: Ahhh, The Defrost Wires....
These wires are a pain. I mentioned before that they're really short and the working space is tight... and since we cut them we kinda had to do it this way. You could try to pull them through the new hatch like we did on the right side, that would probably be better: but here's how we did it.
Basically we stripped both ends of both wires and soldered/taped them together. One of the wires is much thicker than the other, and this one isnt too much of a problem... Just make sure you do a good job twisting it together and solder it well, it should be fine.
The second wire though is a little tougher.
Basically its a tiny little wire that has the hot wire inside wrapped around a seperatly insulated ground wire. The ground wire
inside is EXTREMELY small, so be very careful stripping that second insulation and solder it neatly. Tape this inside part up, making SURE NOT TO CROSS IT WITH THE POSITIVE WIRE! Take your time and do this neatly, you dont wanna have to do this again, trust me.
You can see in the picture us soldering the super small ground wire with the positive wire pushed way back and out of the way... this worked the best for us.
This step took lots of arguing and lots of time... Hopefully with this DIY it'll be a little quicker for you. Jeez, it's night time already!!
NOTES: Yeah yeah I know you shouldnt have that hot soldering iron on that towel.... whatever, better it catch on fire and burn us than I drip solder into my beautiful s13!
Heh also watch out with that soldering iron... apparantly it's really hot! See that mark on my friend's hand in that picture up there? Yeah, I got him with the iron when he tried to slap at a mosquito. Whoah now.
fiznat
Car: S13 240sx x 2
Step Nine: Put It Back Together
The easiest part. Just put everything back in reverse order. Bolt down the new hatch at the top where you removed it, stuff away any dangling wire (and make sure its sealed/soldered/spliced/taped correctly and neatly), put the carpet back inside your new hatch, attach the lifters, snap the inside panels back on and put in the two screws on each side, and do a good job cleaning up all the bits of wire (they hurt if you sit on them, trust me!).
Take a step back and pat yourself on the back. You are so friggin awesome!
NOTES:
-Yeah I know the hatch looks kinda crappy right now, I'll clean it up tomorrow real nice you'll see
-Thanks to ENTITY for the picture hosting, definetly a donation coming his way
-If you have any specific questions about the install or whatever feel free to email me or whatever (its in my profile).
Enjoy everyone, thanks for not posting in the middle of it all!
fiznat
Car: S13 240sx x 2
Postby Toahk » Wed Jul 23, 2003 9:25 pm
Welcome to the no-rust-hatch-crew my friend
--It will stop on a dime and give you 9 cents change--
Visit my Cardomain page
Toahk
Car: 97 ....
Postby driftaholic » Wed Jul 23, 2003 9:25 pm
good job! it was worth the wait. i'll have to go pick up one of those hatches for myself soon
driftaholic
Car: reading nico
Postby SWIFT_DRIFT » Wed Jul 23, 2003 9:25 pm
Note to others who want to replace their rusted hatch: buy one with complete wiring. Theres 3 plugs on the passenger side right above the tire well and 1 ground wire/antenna plug on the drivers side right above where the actual hatch bolts are located. This would make the swap about a million times easier for those of you who don't like to deal with wiring.
SWIFT_DRIFT
Postby chrispy » Wed Jul 23, 2003 9:25 pm
i could have gotten a hatch for $1 , at this junkyard, but i was like nah, It will probably be easier to just remove the rust and weld up the holes. And now i am kicking myself.
1990 Nissan 240sx, de-pig faced
-Redtop sr20det project
up and running. check out my cardomain site page #8.
chrispy
Car: Rowing, wakeboarding ,being outdoors, nissans
Postby slw240sx » Wed Jul 23, 2003 9:25 pm
damn, we opends tha hatch then took out the bolts from between the hatch and the outside roof instead off removing the entire hinge we took it off the hinge it was soo soo cold out and it too forever. we did it tha hard way. we also took 5more mins to peal back the interior panels to find the connector of the hatch harness. only to end up cutting the wires off the car it went on cause it was so cold we didnt feel like messing with the rewiring the plugs. sinnce the wouldnt match up
ForcedFabllc.com
slw240sx
Car: 1990 Ca18det 240sx Hatch
Postby 240sxgirl » Wed Jul 23, 2003 9:25 pm
Fiznat-
Thanks for the diy write up. I just purchased a new rust free perfect hatch for 20 bucks and I was planning to install it pretty soon. I didnt think the hatch would be that big of a job, besides the wiring. Your help is very much appreciated! It is so nice to have a rust free hatch, I was planning on doing some reconstuctive surgery (welding) to it but I got a new hatch with everything in it.
I drive a:
89' Nissan 240sx Se Fastback (project car)
Engine: Ka24e
96' Nissan Altima Gxe
(show-daily driver) Engine: Ka24de
88' Nissan Pulsar NX Se
(summer cruiser) Engine: Ca18det
89' Nissan 240sx Se
(New turbocharged toy)
Engine: Ca18et
240sxgirl
Car: Hot guys, fast cars, both at once.
well even if the connectors really are back farther inside the car, it wouldnt have helped me. the junkyard (and probably most other junkyards) cut the wires on the new hatch with like 1 or 2 inches to spare: not nearly enough to reach a plug inside the car.
Glad this helps, enjoy!
fiznat
Car: S13 240sx x 2
Postby stillmatic » Wed Jul 23, 2003 9:25 pm
Wow, you guys are lucky. I paid $200 for a used hatch with stock spoiler... Grrr.. I wonder how rusty the spoiler is underneath. BTW, anyone know how to rewire the brake light?
stillmatic
Postby corn322 » Wed Jul 23, 2003 9:25 pm
holy crap, a hatch for $1?? I need to go look for one like fiznat got, rear wiper and no spoiler. it's raining all the time now down here in central texas, and it sucks not being able to see behind me clearly
corn322
Car: 1993 240sx
Postby huckedup16 » Wed Jul 23, 2003 9:25 pm
Were there any hatches that came without the rear wiper? Im setting my car up for track only and would appreciate ant weight i can save by purchaseing a hatch without the wiper and motor.
huckedup16
yeah pretty sure some came without the wiper. If you go to car-part.com, you can narrow down your search to a spoilerless with no wiper if you want.
fiznat
Car: S13 240sx x 2
Postby Silent Drifter » Wed Jul 23, 2003 9:25 pm
I cant believe it cost you so much. I got mine for 43 dollars at a junkyard. An your old hatch didnt even look half as bad as mine I had probally 4 baseball size rust spots.
AIM- KApwrdSilvia
Email- e_mai1_me@hotmail.com
Silent Drifter
Postby downhiller101 » Wed Jul 23, 2003 9:25 pm
I've got one of the hatches without a wiper on my car, and i know another guy without it also. i guess i am lucky the living in the northeast didn't rust out my hatch were the spoiler was before i could get the holes welded .
downhiller101
Postby pr240sx » Wed Jul 23, 2003 9:25 pm
Excellent write up
Now, I have a windowless rust free, no wiper hatch to swap for my full of rust, double sided spoiler, rear wiper equiped and good window stock hatch.
How the $%^#&^I can swap this!!
pr240sx
1. install hatch as indicated above.
2. buy new glass and have it installed by a professional.
viola!
fiznat
Car: S13 240sx x 2
Postby Bryson » Wed Jul 23, 2003 9:25 pm
I removed the rust and welded the holes.. only took a few hours one night and it looks hella good. it was free for me too I just helped a dude fix his computer and he did the welding
Bryson
Car: 93 240sx Hatchback /w Sr20
but **** nice write up man and great idea for those who don't have the remove and weld option
Bryson
Hatch
Postby 91SE » Wed Jul 23, 2003 9:25 pm
I hate to be a bastard but shouldn't you have painted that first
91SE
how
If I had the $$ to go and buy a $1185.98 rear glass I would not ask
dont you think :help
pr240sx
hey PR I'm sure you can ake theglass out of yours and put it in the rust-free one, the glass is just held in there by that weather stripping that goes around it and some sort of glazing glue...
Bryson
heh or get glass insurance and, uhm... "wait" for a completely random and strange accident to occur in which your rear glass gets broken somehow??
fiznat
Car: S13 240sx x 2
Next
Return to 240sx Articles
