or men who like to be able to have full control of their carWDRacing wrote:Yeah but the iron block LQ is the same as the LS.
Stay automatic and use a stall convertor. Manuals are for drifting losers...
Not with the stock rack and pinion they arent, unless they are notching the oil pans like the guy from LS1tech.com The rear sump pans (F-Body, C5, C6, trucks, vans) sits right dead center of the steeringwajouba wrote:The pan is 8 and 5/8 inches deep at the rear of the pan - the deepest part. The sump runs 8 and 3/4 inches from the rear of the pan forward. The pan begins to drop down for the sump portion about 11 1/2 to 12 inches back from the front of the pan. If you are putting this into a Nissan then from what I have seen, the guys here in AZ are using the F-body/Camaro pan.
This was the description of the seller... Camaro Pan on a 240sx is a NO NO... its a Rear Sump...
