240sx dashboard lighting modification
Postby attwater » Fri Apr 28, 2006 9:27 am
Sorry for the delay. Our cars come with some pretty cheap/poor looking yellow/white'ish lights for the dashboard. These are pretty simple to change.
HVAC unit - Remove the coverplate and then the stereo headunit. Remove the four screws holding in the HVAC unit, push it in, and then drop it down into the space previously held by the stereo. You can now pull it out towards you. The lightbulbs are underneath a plastic flap on the topside of the unit. Its been awhile, but I believe that there are two tiny bulbs with white bases that you can quarter turn out with a screwdriver. Replace them with LED's. My pioneer headunit was lit with green and blue, so I went with blue led's to match. Take a drive over to the autostore and pick up a set of LED's. Mine came in three packs for $7. All you want to buy is the LED bulb with two wires and a tiny resistor (which is built into the wire) coming off of it. No need for fancy led's with mounting hardware and cigarette plugs. Cut the wires short (don't cut off the resistor) and solder them directly onto the circuit board contacts that were previously touching the lightbulbs. I beleive that I used two LED's (one for each hole). Solder the wires very carefully with a pointed tip on your soldering gun. Then carefully push the bulb straight down into the hole where the incandescent bulb sat. I will include a picture. The resulting HVAC lighting is blue (in my case) and looks just like the bright blue lighting in VW's. The little lights on the sliders will remain green as they are merely filters.
Shifter - pull out your ashtray and you should be able to get to the bulb lighting the shifter column. Slide a gel cover over it or replace it with a red bulb. Avoid the pre-made blue bulbs as they tend to fade back to white pretty quickly. Red is very bright and will never fade.
Gauge pod - Hopefully you all know how to get the pod out (that's a separate set of instructions). In my case, I purchased reverse indiglo gauge covers a number of years ago when they weren't so trite. I left them in because they still look good... The problem was that my odometer and clock still glowed a nice cheesy yellowish. I pulled the bulbs from the back of the pod (I only replaced the bulbs nearest the clock and odometer. Best bet there is to use gel covers (autostore). I went with red. The clock and odometer now glow a very attractive and bright red which matches the red numbers on my gauge faces. You can easily fit all of the bulbs with gel covers if you do not have indiglo faces. I have done that to another car and the results were great. LED's work well too (see HVAC unit). Tip for people with white faced gauges: color the front of your clear needles with a blue sharpie (tm). It looks great and you can see the needles against the white background. They will still light up from the sides and back.
Convertible top / cruise control switches - Normal LED's are too bright for these. Yank the switch straight out. Grasp the front of the switch and pull. Go practice on a junkyard car. You can then see the tiny bulb. I cut a gel cover into sections and glued them in place. You can also try weak LED's from radioshack.
Am I missing anything?
attwater
Car: 1993 240sx convertible
Re: 240sx dashboard lighting modification (attwater)
Postby attwater » Fri Apr 28, 2006 9:28 am
having problems with the pics. i'll figure this out and get them posted
attwater
Postby donmeca2020 » Sun Apr 30, 2006 5:11 am
just about to say wanted to see finished product before i would try doing this
donmeca2020
Car: 2005 lancer evolution and 1993 240sx convertible
Re: (donmeca2020)
Postby jamesblonde82 » Sun Apr 30, 2006 4:05 pm
sounds hot. lets see the dash lit up at night. bet it looks pretty sweet.
jamesblonde82
Car: 1992 Nissan 240sx convertible RIP 5/10/07 1993 Nissan 240sx convertible
Postby attwater » Sun Apr 30, 2006 6:05 pm
Here are the pictures. It is extemely difficult to make a camera shoot pictures in the dark of bright dashboard lighting. This is the best I can do and it doesn't do the car justice. The clock is not brighter or a different color than the odometer, the camera makes it appear that way. The HVAC and headunit are both the exact same color, crispness, and brightness, but the camera shows them dim and washed out. Enjoy...
attwater
Postby attwater » Sun Apr 30, 2006 6:06 pm
pic 2
attwater
Postby attwater » Sun Apr 30, 2006 6:07 pm
pic 3
attwater
Postby JSvert240sx » Mon May 01, 2006 4:48 am
Sweet! the thread I've been waiting for...
I was at radio shack and they had a pretty weak LED selection... which autopart store did you find your LED's at?
-John-
1993 240SX Convertible
JSvert240sx
Car: 1993 Nissan 240SX Convertable
Re: (JSvert240sx)
Postby attwater » Mon May 01, 2006 5:02 am
autozone. I still have an unused package of LED's. I will take a picture of them tonight so that you know what to look for.
attwater
Re: (attwater)
Postby jamesblonde82 » Mon May 01, 2006 5:45 am
rock on man
jamesblonde82
Re: (attwater)
Postby JSvert240sx » Mon May 01, 2006 7:25 am
attwater wrote:autozone. I still have an unused package of LED's. I will take a picture of them tonight so that you know what to look for.
Thanks, this is going to be my project for next weekend.
JSvert240sx
Re: (JSvert240sx)
Postby attwater » Mon May 01, 2006 8:53 am
post some pics when it's done.
attwater
Re: (JSvert240sx)
Postby attwater » Mon May 01, 2006 8:41 pm
http://www.autodirectsave.com/LED_lights_wired.asp
here is a good example. I will upload the pic of the 3 pack I bought when I am able. They were Pilot LED accent lights (3 pack).
attwater
Re: (attwater)
Postby JSvert240sx » Tue May 02, 2006 3:21 am
attwater wrote:post some pics when it's done.
Deffinately, I already have the reverse glow gauges installed... I put them in three years ago before they were pretty played out, but I still think they look really good. The black gauges were just too boring for me back then and I wasn't ambitious enough to try anything else at the time.
JSvert240sx
Postby jonesbplayer » Tue May 02, 2006 6:05 am
yess!!! attwater thanks a million, i'm getting started today
you are the man
jonesbplayer
Car: 93 nissan 300zx 2+2
Re: (JSvert240sx)
Postby JSvert240sx » Mon May 08, 2006 4:03 am
Did the LED mod on Saturday and took tons of pictures while doing it... Here I'll post the before and after pics and if anyone wants I'll continue Attwater's how-to with some detailed pics and instructions...
before (bezel removed)
after:
JSvert240sx
Return to 240SX Convertible Forum
