240sx automatic to manual transmission conversion s13 and s14
Postby 180fan » Fri Jul 21, 2006 11:53 pm
s13 from our very own mod tenkawa_akito
http://forums.nicoclub.com/zerothread?id=77784
S14 from nighkid86
http://forums.nicoclub.com/zerothread/181139
Now this is stickied for both s13 and s14 owners. You post a question about this, I'm going to lock it down. Learn to use the search function or look at the top of the page maybe?
1. Search
2. Lurk moar
3. Don't post till you've searched
4. Don't forget details. We're not mind readers over the internets.
180fan
Car: 89 fastback
Re: 240sx automatic to manual transmission conversion s13 and s14 (180fan)
Postby nightkid86 » Fri Dec 22, 2006 4:56 pm
Supplement on removing a flywheel:
There are a few ways to get an automatic or manual flywheel on or off.
The easiest by far is to have an impact gun. A quick ziiiip and the flywheel is on the ground. If you don't have an impact gun the flywheel will spin as you try to take it off, you can attempt to brace the flywheel using screwdrivers and such, while holding the crank pulley with a 27mm socket.... or you can use this secret:
EASY WAY TO GET ON AND OFF A FLYWHEEL: upon doing a clutch swap a year or so after my 5 speed conversion, I ran into a really easy way to change the flywheel. Basically you get a new bolt (and possibly a nut since the a/t flywheel isn't threaded) that will fit into a hole on the flywheel (the hole not used to bolt to the crankshaft) and use a bellhousing bolt. Run a chain between the two bolts as shown in the diagram below. it doesn't matter if the chain is too long, the excess can just dangle. Put the chain on and then turn the flywheel to add tension to the chain. The chain will now keep the flywheel from spinning. This works great to hold the flywheel if you don't have an impact gun. Wrench away.
nightkid86
Car: 97 S14 SE
Postby Hijacker » Sun Dec 24, 2006 6:39 am
The chain idea is an awesome idea. Usually I've just had someone hold the crank still on the front while I use a breaker on the rear. If you have an impact though, you should be able to get the bolts off with no problems.
Hijacker
Car: '92 240sx Convertible
'11 Pathfinder
Postby jr_ss » Fri Dec 29, 2006 3:42 pm
I would like to add some info to the S14 procedure.
I'm getting ready to do my swap and in taking some conversion steps early I found that when drilling the hole for the MC, a perfect size to use is 1 3/8th's hole saw. It's slightly larger (about 1/32nd larger) than the protrusion on the rear of the MC. This size will allow the rubber to be pinched inbetween the bulk head creating a "waterproof" seal, not that any water would get there but it'll also help with the road/engine noise in the cabin. I would imagine that the S13 MC would be similar if not identical to the S14 and use the same size hole saw, but do not hold me to that as I do not have an S13...
Glenn
l 95' S14 l S14 Sr20 l Whiteline l Cusco l Z32 brakes l 350z Rays l
l Jdm Aero l SPL l Fujitsubo l RPS l Apexi l DSS l Defi l Tomei l
OG ZMFL member #1
jr_ss
Car: 95' S14
Postby Soravia » Fri Mar 16, 2007 1:18 pm
I used a steel pipe on the rachet to get leverage and loosened it from a good angle to minimize the flywheel spin. I didn't have help so I used another rachet and pipe to hold it from at one of the bolts. On the last one I re-bolted the one before with anti-size, plastic/brass washer to make hold for the last one. It was tricky but did the job for a poor man. (actually the air compressor plug was broken)
2003 A4 1.8T Quattro
2001 Mazda Miata LS
Soravia
Car: 2003 Audi A4 1.8T
Re: (tenkawa_akito)
Postby silman180 » Sat Mar 17, 2007 11:03 am
hey im new this forum stuff can you give me some pointers on posting questions i see your online
silman180
Car: 93 240
Postby xTearsFallForeverx » Sun Mar 25, 2007 11:24 pm
the best way is if you can get at least 1 bolt off, get a long box wrench and bolt the closed end to the flywheel. use that to hold the flywheel while you take the others off. worked great for me. was my grandpa's idea. man comes up with anything. made a valve spring compressor once out 2 pieces of wood and a jig saw. lol
1990 s13 now>>KYB GR2, Eibach Sportlines, 2 1/2 catback, OBX N1 Style muffler/ Walbro 255/ Fidanza Flywheel, underdrive pully on crank, MSD Blaster 2 Coil.
xTearsFallForeverx
Car: 1990 s13 Fastback
Re: (xTearsFallForeverx)
Postby drewc87 » Sat Mar 31, 2007 3:20 am
is an 89 5sp sohc trans and a 93 dohc trans both the same? and does anyone know if an 89se has abs from the factory?
andrew_conolly@yahoo.com
drewc87
Car: 00 celica gts/93 s13/98 cbr600 f3/89 toyota p/u 4x4/04 crf50
Postby 10sec240 » Wed Apr 04, 2007 10:14 pm
Hey how much would an s13 full manual transmission swap cost on a 1989 240sx?
10sec240
Car: 240sx
Re: 240sx automatic to manual transmission conversion s13 and s14 (10sec240)
Postby j-nasty » Sun Apr 15, 2007 2:43 am
10sec240 wrote:Hey how much would an s13 full manual transmission swap cost on a 1989 240sx?
If you get someone else to do it for you I've seen the prices go up to around $1,400.
j-nasty
Car: 1997 240sx
Re: 240sx automatic to manual transmission conversion s13 and s14 (Soravia)
Postby dnoiser » Fri Apr 27, 2007 1:33 pm
looks nice and clean im impressed how easy it is to find a good body here in usa (im german) our datsuns and nissans where all f"{+ UP
I HAD A 96 240 sx se before i bought the 180 everyone told me i shouldnt haha but damned i love fastbacks
btw i never touched the techical **** before i came to usa but this nissans make u a grease monkey hehe
i think we all love it ;-)
have a good one
btw im always interested in tips and hints to make it tight
dnoiser
Car: nissan 180sx stage 4
Postby dosusx » Tue Jun 05, 2007 5:30 am
So if i find a mint s14 auto owned by a grandpa or grandma, this swap will make it exactly like a manual? its the same setup and parts how the manual is? it wont have any problems once i swap for a sr20 and new trans later?
dosusx
Re: 240sx automatic to manual transmission conversion s13 and s14 (nightkid86)
Postby hookup » Sun Jun 17, 2007 4:45 pm
for less money and faster shifts you can get a shift matic
http://www.ipttrans.com/nissanauto.shtml#main
hookup
Car: 240SX VERT
Re: 240sx automatic to manual transmission conversion s13 and s14 (dosusx)
Postby hookup » Sun Jun 17, 2007 4:52 pm
hookup
Car: 240SX VERT
Re: 240sx automatic to manual transmission conversion s13 and s14 (hookup)
Postby iseenem240SX » Thu Jun 28, 2007 7:00 pm
Anyone running a '95 5-speed transmission on a 97-98 240SX? After auto ECU swap to a MT ECU, CEL came back on after 100 miles.
iseenem240SX
Car: 1998 240SX SE
Postby whenthesunsleepsx » Mon Jul 09, 2007 12:13 pm
assuming that i do the labor, can someone give me like an estimate on how much a manual conversion would be for my 91 s13 240sx coupe, or if anyone did it themselves how much it cost them, i'm trying to get an idea before i start trying to pull this off...thank you
whenthesunsleepsx
Re: 240sx automatic to manual transmi ... (whenthesunsleepsx)
Postby bone_stock_240 » Mon Jul 09, 2007 12:22 pm
I have seen people buy complete swaps for between 200 to 500 bucks. Any more than that, and you are getting ripped off. Welcome to Nico!
bone_stock_240
Car: 1995 Infiniti Q45
Postby SWAT Team S14 » Thu Aug 16, 2007 6:03 am
nice idea.....wish i woulda read this before........
SWAT Team S14
Postby KnoxVegasS13 » Thu Sep 13, 2007 1:59 pm
I got mine for like 500 bucks.
91' 240sx SR20DET
KnoxVegasS13
Car: 91 Nissan 240sx w/S13 Triple Projection Conversion and SR20DET
Postby marcus 23 » Wed Sep 19, 2007 6:08 pm
i resently had someone install an sr20det s14 into my 95 240.The car was auto i bought a front clip and gave everything to him and ever since i got the car back it's bin problems.The wipers and reverse light dont work the the car goes into safe mode if the car is left to idle...i need some help with the wiring
marcus 23
Car: 95 240sx
Re: (marcus 23)
Postby JDS Performance » Mon Nov 05, 2007 1:25 pm
I have a DVD on the AT-MT swap - its pretty dang detailed too!
JDS Performance
Vendor
Postby KGB » Mon Nov 05, 2007 9:11 pm
hey guys, I seen this topic and was already wanting to post a topic on tranny swaps. First, I am assuming that the creator of this post wants to know the price on swapping a manual tranny into their 240. Of course it all depends on whos doing the job. Some guys can charge you an arm and a leg, and if your lucky some guy will want to sleep with your girl either way its one hell of a price for the job. The tranny alone can cost from a few hundred to even a grand or so.
My question is though, can the trannys from 89-99 intermingle? Cause right now my auto tranny on my 89 240 is shot, and want to swap a KA24de later on.
KGB
Car: 1989 Nissan 240sx & 2007 Ninja 650r
Re: 240sx automatic to manual transmission conversion s13 and s14 (KGB)
Postby JDS Performance » Tue Nov 06, 2007 1:43 am
99?? 98' was the last year.
Yes the trannies will work on each other - the s14 ODBII has the crank angle sensor ontop the bellhousing - so there is a hole up there
where the s13 does not use this sensor - you can swap bellhousings the gear box is the same - the rear housings is the same
you can no use the auto speed sensor in the 5 speed - and you can not use the s14 speed sensor on a s13 or vise versa
It cost me around $1500 for my swap - but I did alot of upgrades while I was doing it all - plus I installed the 5 speed brake booster/pedal ect I went the extra mile to do it right.
JDS Performance
Vendor
Re: 240sx automatic to manual transmiss ... (JDS Performance)
Postby matthunter8819 » Tue Nov 06, 2007 10:46 am
thanks for the help
matthunter8819
Car: 92 nissan 240sx coupe
Re: 240sx automatic to manual transmiss ... (matthunter8819)
Postby JDS Performance » Tue Nov 06, 2007 11:04 am
no problem LMK if you need anythig else!
joshds25@yahoo.com
JDS Performance
Vendor
Postby skylinegtst93 » Tue Nov 13, 2007 8:19 am
good infor
skylinegtst93
Postby smoothfilipino » Wed Nov 21, 2007 10:29 am
hey i have a 98 nissan 240sx se. and the only thing iv done to the car is suspension. i want to get a swap from auto to manual. does ne one know how much that would cost plus what parts i need to buy
smoothfilipino
Car: nissan 240sx
Re: (smoothfilipino)
Postby JDS Performance » Wed Nov 21, 2007 2:28 pm
My 5 Speed Swap DVD is your best friend
http://www.240SXTECHDVDS.org
JDS Performance
Vendor
Postby AH240sx » Fri Nov 30, 2007 7:12 pm
Omg it sucks not having a garage. Nor having friends who put cars in garages.
AH240sx
Re: (AH240sx)
Postby JDS Performance » Sat Dec 01, 2007 3:23 am
rent a storage building - thats how I started out
JDS Performance
Vendor
Next
Return to 240SX Technical Forum
