20x11 35mm fit 06 m35 sport ?
Cabo
Car: Infiniti M35 sport 2006
Nissan pathfinder LE 2002
What's up guys I'm new here and was wondering if I can fit 20x11 with 35mm offset in the rears even with a lil stretch... I'm also going to install coilovers to have it sit right. Let me know if anyone experience this
DoN_BLaZe34
Car: 2007 M45 Sport - Sold
2006 FX45 - Traded
2014 Q70S 5.6 - Sold
2017 Q70L 5.6 - Current
I'll never claim to be an offset master, but to me that seems like it'll poke out past the fender unless you roll them and then dial in some camber..
I'll let the experts chime in though lol.
The Bodyguard
Car: 08 Infiniiti M35 black loaded custom VIPDOUT
08 Infiniiti G35 S sold 92k miles
08 Infiniiti M45 S sold 78k miles
07 Infiniiti M35 traded 53k miles
95 Infiniiti J30 sold 155k miles
Location: Cypress, TX (Houston) o.g. from southern cali (North Hollywood)!!
Ooh yes, :chuckle: but like you mentioned on your post... With a little (a lot) stretch and camber anything is possible!!! With those specs you won't be able to roll with stock alignment specs so after you lower it have your alignment guy at the shop dial in the much needed camber :bigthumb: no need for adjustable control arms or alignment kits... Just enough spare tires and/or tire flipping(inside to outside)!! :dblthumb:
Cabo
Thanks guys.. I just came from having a g35 coupe on -3 offset all around flush look and now I have a 2006 m35 sport and wanted to know what's the lowest offset and widest rim I can run with little stretch for a flush look but without any modding fenders since rears are basicly rolled already. Like I said I don't mind a mild stretch :)
mexillis
Car: M45s
Put a 245 on it and some camber, should fit.
Cabo
Ohh ok.. It's a daily driver so that much stretch my not be safe.
Cabo
20x10 35offset squared on m35 sport? Is anyone running that?
The Bodyguard
Cabo wrote:20x10 35offset squared on m35 sport? Is anyone running that?
One member off the top of my head... 20x10 +40 275/30/20 for your +35 offset a Lil stretch would be perfect!! On 10" wheel you could put a slight stretch 265/35/20" or 255/35/20". Since you're talking about stretching stick with a35 series tire I wouldn't go with 30 series four stretched toes... :gotme
That should work!! :dblthumb:
Cabo
If I can't figure out if I can fit 20x11 with 35offset with atleast a 255/35/20 on it ill probably consider trying to fit 20x10 all around
RM450GT
Car: 06 M45
I used to run 20x10 et38 w/ 275-30-20 lowered on espelir springs in the rear with no problem
Cabo
I wanna go as flush as I can but on coilovers with no fender work
mexillis
Car: M45s
Cabo wrote:If I can't figure out if I can fit 20x11 with 35offset with atleast a 255/35/20 on it ill probably consider trying to fit 20x10 all around
That should fit and maybe even a 265/30. The norm is 10.5+45 with either a 285 or 275. So if you have rolled fenders or don't mind poke you can make the 11" wide rim fit. It all depends on how much tire you want to fit.
06M4.5
Car: 2006 M45
I'm in for pics
I want to see the 20x11 et35 :cool:
Cabo
Would 265/30/20 cause less camber wear since wider? Then the 255/35/20
mexillis
Car: M45s
Idk for sure but I would think the more contact patch the better. I have -3.5 camber on the rear and haven't needed to replace tires yet with over 15k miles. I you don't have tires yet look into nitto neo gen. Ohh and there's an M owner with 20x10+38 all around and has 275's I think.
Cabo
Ya I seein looks pretty good... I wish there was someone that ran the 20x11 with 35offset... I seein a 2008 gs lexus running that size but idk if there's a big difference between the m and the gs with the offsets
Cabo
20x10.5 38 offset?
The Bodyguard
Cabo wrote:20x10.5 38 offset?
That size should be nice!! Just a little bit of poke and tires for the 10.5?? I ran 265/35/20 and the fitment was awesome!! So much contact to the ground and the stretch was very minor but helped tuck the tire in while slammed on d2 coilovers. I wouldn't run 275/30 I liked the 265/35/20 combo better!! :bigthumb:
Cabo
What offset were u running?
