Q451990 wrote:What are you trying to change with the new bushings? Are those grease fittings?
One of the OEM rubber bushings I purchased and installed a few years ago (
) with the A model bars split open and worked its way out of the housing. I found it hanging from the bar about 2 inches from the housing. In winter the bushings would get noisy and make a "creaking" noise that I managed to remedy a couple of times by removing rubber bushing and applying some grease to the bar. As soon as the weather warmed up, the creaking sounds would disappear.
Last fall I didn't do my annual grease application ritual. So about a month ago I heard the creaking noise then a metal-to-metal scraping sound that turned out to be from the bar rubbing against the bushing housing. That must have been when the bushing split.
That grease fitting looks like a good deal to me.
