yappering »
https://forums.nicoclub.com/yappering-u262575.html
Mon Mar 14, 2016 9:26 am
This fuse box is located in the passenger compartment on the Driver side. I updated the subject to reflect this. I believe there is a fuse box in the engine bay as well.
Also, I was able to add a circuit to DC_DC 10A fuse for a switched circuit for radar detector and run the wire along the driver side pillar into the headboard for a clean install. You can carefully pull the pillar slightly and tuck the wire under.
I am not sure about about all of the other fuses but the DC_DC 10A fuse was the only one that would turn off the radar detector after turning off the ignition of the ones that I tried.
Has anyone had any experience with tapping into ALWAYS ON fuses? Does it drain the battery? I was thinking about installing a dash cam.
