This time, it's a Chrysler 200. This was a reasonably well-featured model, but with the Tigershark 2.4 liter I4. It had a 9-speed ZF automatic which is now officially my Arch Nemesis. I think I'd rather have a Nissan CVT. Yeah.
It looked like this:
Styling
5/10
I don't really care for FCA's current über-round styling scheme, nor the oversized-cabin proportions. (Isn't this the company that created elegant "cab forward" models like the 300M? What the Hell happened????) Chrysler's details are distinctive but bland; I recognize them as Chrysler but they don't really say anything particular. The c-pillar/decklid/backlight area is spectacularly blah. Not BAD, just blah. Too much round. Not enough style.
Interior
5/10
It tries. It employs some neat ideas. It also employs some exceedingly terrible ideas. The layout is utterly nonsensical. There are very few physical buttons, while most functions are buried in menus--a monumental Cardinal Sin that I thought we had moved past years ago. It's an incredibly distracting car in which to perform basic operations (like changing the HVAC vent mode).
The gear selector is a Jaguar-alike knob, except nowhere near as well executed. The gear knob is moronically located on the same chunk of console as the knobs for HVAC and volume. It's also the most driver-ward knob of the bunch, so it's the one your hand finds first when keeping your eyes on the road. I'd be stunned if there weren't people who accidentally turn the volume down to "Park" while cruising on the highway. Terrible, awful, abysmal layout.
The gauges are (like so many wannabe-upscale cars these days) ringed and highlighted with unnecessary blue. It looks tacky and is hard on the eyes.
The center console, absent the shift lever, is very minivan-like. It has TONS of storage space and is slightly reconfigurable. Unfortunately, despite the clever sliding multiposition cupholder, the arrangement of the storage spaces is such that they're not really beneficial while in motion. I can see the cubby under the dash being useful for purse or backpack storage, but not for anything needing retrieval while in motion. There is a smart cable passthrough from the lower console section where the power outlets are.
You can see the shift knob here, as well as the touchscreen which houses most of the controls. The touchscreen has six discrete modes, which is a huge waste of display real estate. It's impossible to view media info (song title, etc.) alongside HVAC settings. One or the other. Technically there's a tiny fan speed and temp display at the top when in Media mode, but to see anything more you need to hit the button for "climate" mode. Even my dad's now-older Maxima with the LCD screen showed media info, HVAC info, compass, temp, time, etc. all at once. The Chrysler doesn't even try. It's very tedious, especially with the discrete mode select buttons scattered around the bezel.
The temp and fuel gauges are vertically arranged between the tach and speedo and bordering a small LED screen. They consist of INDIVIDUAL ENORMOUS LED LIGHTS which illuminate one at a time as the gauge fills. It's like my 1984 DeVille all over again, except without the touch of class. The 200's fuel gauge is THE SINGLE TACKIEST INTERIOR ELEMENT I have ever seen in a car. Just unbelievable. Who pushed it through to final production? What are they doing working on automobiles? Who gave them permission to think?
There's an LED display between the tach and speedo, which is far more useful. Irritatingly, though, when using cruise control, it shows text updates to override the current screen for a few seconds ("Cruise control now available" or "Cruise control set to 80" -- utterly unnecessary and redundant).
Oh, also, I had a hearty chuckle at the very prominent labelling of the gauges:
Thanks for the tip, Chrysler. I wasn't sure WHAT those numbers meant.
The seats sucked. Absolutely zero support. Even moderate corners left me sliding all over. No bolstering anywhere. The seat bottom felt too short, too. Wide and short, just like all modern cars. Exactly backward and exactly wrong.
Powertrain
PICK A DAMN GEAR AND STAY IN IT out of 10.
This was easily one of the most unpleasant and inconsistent powertrain combos of any car I have ever driven. It was really miserable.
As noted above, the 200 has ZF's new 9 speed auto. It has exactly 3 too many gears, but it shifts exactly forty-seven billion times too often. It shifts ALL THE TIME. ENDLESSLY. UNCEASINGLY. INCESSANTLY. Shifts, shifts, shifts, shifts, shifts, shifts. It REFUSES to stay in a gear and just cruise there. Even on perfectly flat, straight, even terrain at freeway speeds under cruise control, it is constantly dropping to 8th. It feels BIZARRE and really unnatural. It's an unexpectedly offputting sensation. You set the cruise at 80, and the car spends the next hundred miles dropping to 79, downshifting to 8th, accelerating back to 80, then dropping to 79, downshifting to 8th, and you get the picture.
The SLIGHTEST hint of even moving your toe toward the accelerator drops at least one gear.
Here's the problem:
This engine is GUTLESS.
It has the peakiest powerband I've seen outside of a 1973 Yamaha 250 two cycle.
Not only is it gutless, making absolutely NO usable power below 4000rpm, but the transmission also REFUSES to let it actually make any power.
That effing ZF abomination does everything it can to keep the car under 3000rpm. The Tigershark makes approximately 3 llamathrust at 3000rpm. For those not familiar with Imperial conversions, that's about enough power to lift an empty McDonalds fry container 3 milimeters.
So, you end up with a car that's constantly shifting to find power, never actually finding any, and struggling desperately just to maintain a constant speed.
In stop-and-go city traffic it's a complete nightmare. You'll shift 3 times before you get through the crosswalk at an intersection. And every shift is accompanied by a palpable, jolting absence of power. And every time the engine starts to feel on the cusp of making power, it shifts AGAIN. And again and again. And again.
ALWAYS.
F@#%ING.
SHIFTING.
It's like some kind of bad '70s made-for-TV horror movie. It's not even scary but it WON'T GO AWAY. IT WON'T STOP BEING TERRIBLE.
JUST SHIFTING ALL THE TIME.
It's hard to articulate exactly why it's so uncomfortable feeling. But when you're used to driving real cars that make real torque and have real gear ratios divided between a sane number of cogs, the behavior of the 200's powertrain is jarring and distracting and makes you feel like you're driving it wrong. The constant-but-barely-perceptible shifts in inertia really mess with the sense of feedback from the car. It's like the car doesn't want to actually go anywhere, it just wants to shift a whole bunch and feel damn good about it.
The kickback for all this gearbox obscenity is that the car manages a cool 32mpg combined. For a midsize car, that's not too shabby. However, as I'm always quick to say: if you're buying a car for MPGs, you're doing it wrong. And the tradeoff here is absolutely, unequivocally, undebatably NOT WORTH IT. The cost is orders of magnitude greater than the return.
The engine itself is really harsh. The idle is ridiculous, and it grinds and groans under "power" (heh). The fact that it's forced to stay in the low rev-range certainly does nothing to disguise this undesirable trait. At least the exhaust note doesn't sound like much of anything at all. You can pretend it's not there, for the most part. Or, well, you could, if that GODAWFUL TRANSMISSION WOULD LET YOU.
I would honestly, sincerely, absolutely genuinely rather have a Nissan CVT than this 9-speed monstrosity.
Handling
Something out of 10
I really can't speak of the handling. It wasn't sporty, and it wasn't luxurious. It was exactly neutral. You steer the car and it goes that direction. That's really all I can think of to say about it. I can't even rank it out of 10 because I don't understand what I'm ranking.
Features and extras
This 200 had power seats, bluetooth, XM, HID headlights, and single-zone manual climate control. It had a manual-dimming mirror of a different aspect ratio than the rear view itself, with strange plastic protrusions at the top and an oversized housing. The sound system sounded muddy and dull, and no amount of tweaking (i.e. tapping at the inane touchscreen) corrected this.
The bluetooth audio link also exibited a highly obnoxious trait I have never encountered in any car before: skipping. Songs would occasionally skip for half a second before resuming, sometimes just once, and sometimes several times in succession. I have no idea how bluetooth can skip, but the 200 managed it. It's not my phone, as it has never done this in any other car, and I tried it with another device as well.
Overall:
Give me a CVT or a cyanide pill out of 10
Don't buy one of these.
They're horrible.
