JohnD »
https://forums.nicoclub.com/johnd-u171952.html
Tue May 14, 2013 6:54 am
I think you may be confusing Sport Mode with Manual Mode.
When you move the shift lever to the left from Drive, it puts you into Sport Mode, not manual mode. In Sport Mode, the transmission still shifts automatically, but it holds lower gears longer than in Drive Mode.
If, from Sport Mode, you move the lever forward or back to manually select a higher or lower gear, that puts you in Manual Mode and the transmission will hold the gear you select until you move the shift lever back or forward to select another gear, or move it to the right to return to Drive Mode.
