( Terms: Diff= Difference Sw= Side Wall Sh= Shoulder Height Rev=Revolutions MI= Miles OD= Overall Diameter )
2013-2015 NISSAN ALTIMA SEDAN 2.5 - 2.5 S
Bolt Pattern: 5x114.3 OR 5x4.5
Hub Size: 66.1
Lug Nut: 12X1.25
Lug Type: NUT
Offset MM: 35-45
PLUS_____TIRESIZE______SW____SH___OD__
OE-16____215/60-16_____8.5___5.1___26.2
PLUS-17__215/55-17_____8.5___4.7___26.3
PLUS-18__235/45-18_____9.3___4.2___26.3
PLUS-19__245/40-19_____9.6___3.9___26.7
PLUS-20__245/35-20_____9.6___3.4___26.8
____________________________________________________________________
2013-2015 NISSAN ALTIMA SEDAN 2.5 SV - 2.5 SL
Hub Size: 66.1
Lug Nut: 12X1.25
Lug Type: NUT
Offset MM: 35-45
OE-17____215/55-17_____8.5___4.7___26.3
2013-2015 NISSAN ALTIMA SEDAN 3.5 S/SL/SV
Hub Size: 66.1
Lug Nut: 12X1.25
Lug Type: NUT
Offset MM: 35-45
OE-18____235/45-18_____9.3___4.2___26.3
TIPS & SUGGESTIONS:
- The Plus Sizes you see on the screen are not guaranteed exact fitments, but suggested sizes that have been tested to not cause rubbing or complications with application. Modifications such as Decreased Vehicle Height are not put into consideration and are based on a stock suspension.
- Adaptations might be necessary for Plus Sizes such as, but not limited to: Billet Adapters, Hub Centric Rings/Spacers, Aftermarket Wheel Lug Nut Kits, and any other necessary accessories.
- If you do choose to go for a plus size understand tires require different amounts of air pressure or better known as PSI to be properly inflated. To prevent having over/under inflated or your tire pressure symbol light on, might I suggest that you have your TPMS sensors reprogrammed to the correct Maximum Air Pressure indicated on the tires you purchase (Which varies between sizes). You can get this done at any Indy shop or dealer equipped with the proper TPMS/ODB Scanner Tool.
Guys I hope this little Topic Helps, if you've had success with other fitments or have more input to provide regarding wheel/tire set ups you've tested in the past, it is greatly appreciated if you post it down bellow, ill add it to the list, so long as you mention the Year, Make, Model Altima you used and its tire (Brand/model) and wheel specifications.
If you have any questions feel free to PM me or comment down below ill try my best to respond accordingly. I can do comparisons if you have concerns regarding differences in sizes example bellow:
2015 Nissan Altima 3.5 SL ( Terms: Diff= Difference Sw= Side Wall Sh= Shoulder Height Rev=Revolutions MI= Miles OD= Overall Diameter )
________TIRE SIZE____SW/DIFF__SH/DIFF___OD/DIFF/%____REV/MI/DIFF__MPH/DIFF
OE:_____ 235/45-18____9.3/0_____4.2/0_____26.3/0/0%_____790.9/-0_______55/0
PLUS 20+:245/35-20____9.6/0.3___3.4/-0.8__26.8/0.5/1.9%__776.1/-14.8_____56/1
