alright, after a few mins figuring out why we can't direct post pics, then figuring out how to go about posting. here's the deck install instruction pics.
http://s1054.photobucket.com/albums/s48 ... 20install/
tools needed, plastic putty knife (or something more rigid) (i used mine with the metal one) and a philips screwdriver, and a torx 20 driver.
pry up the base of the trim, then pull with hands. disconnect the 4-ways switch, i left the airbag light connector in place. unscrew the 4 screws ( make sure the bottom 2 you have a grip on, one of mine fell in behind and is still AWOL) and then the torx screws holding the radio. I reused the brackets for the new dble din i installed. and as mentioned before you will want a trim ring for the aftermarket.
the extra pics are of the car side harnesses. 2 of them I have no idea what exactly is happening but i do believe the larger one is for steering wheel controls and the other for the factory i-pod controller.
