So for the coming year:biggie wrote:Plans or at least 'hope to's":
Put parts on that currently have:SPL FLCA for coupe- DONESwap FLCA (new with whiteline bushing) from coupe to Vert - Not yetRUCA on Vert - Not yetTurbo parts on coupe, after swapping for lower mileage engine- DONEReplacement taillight for Vert (crack)- Not yetSS braided brake lines for Vert- Not yetNew Hawk HPS pads on both cars- soon
To buy:Few small turbo pieces (maf pigtail, etc) - DONEWider wheels/tires for coupe- DONEACT Clutch for coupe- DONEAlignment for both cars - Coupe yes, Vert no
I plan on finishing the bodywork on the car first. Then following someones build on here as faras upgrading the intake and turbo on the rb25. and also lower the suspension on the car as well but that shouldnt be hard since the coils are already on there. I wanna hit the track and see what times i can get in virginia and maryland and hope that i dont suck too much. learn how to drive good on courses at high speeds and drift a little bit so i can rip up some good used tires as well. should be a fun year for the car. as far as this past year with the car i have succeeded in what i planned to achieve for 09 and maybe the same will happen in 2010. and to also avoid it when people do not interject constructive thoughts and would rather talk down to me or anyone that is simply having fun in what they are doing.Coolwhip wrote:Yes, it's that time of year again and I figured I would start up the fun by hearing everyone's 2010 New Year's Resolutions for their 240sx/Project car.
For last year's resolutions (for reference)...2009 zerothread?id=392863
How it works, let everyone know what you plan on doing over the course of 12 months with your car:
What Mods do you plan on buying / installing?
What type of Build do you plan?
What time do you want to run? track related?
Track times, events, magazine spots, 12 months on jack stands?
And any other car related goals for this year.
Did you finish your 2009 goals?
Then we can all look back a year from now and see what we've accomplished.
Ditto...at least until I find a real job. I just want to hook up A/C, replace my power steering pump, and fix my exhaust leaks.numbnuts240 wrote:my 2010 resolution is to not drop a dime on my 240 unless it's maintenance related.
+1Warped161 wrote:I want to have a running engine.
that is all.
