S13AL wrote:It's going to be nice once you get the wiring out of the way. Keep up the good progress.
I am actually enjoying this part, but you are correct, It will be nice
BigTDogg (MA) wrote:I've found those white Scotchlok connections to be less than reliable for joining two wires together. I had to cut them out and butt-splice/crimp some connections to my door actuators because they weren't getting enough juice across the small metal connector in the Scotchlok. I changed nothing but the connection method and the actuator worked perfectly. Just my expereiences I'd figured I'd share.
I hate those things! I agree with you about butt-splice/crimp.
USsil80 wrote:is the rheostat the dimmer for the dash lights???
Correct. I ordered one and should be able to dim the gauges. I'm going to need to make a few modifications to the wiring...stay tuned...
I ran the fuel pump wire and the fuel quantity wires along side of the original harness today. The fuel pump wire is 14 gauge and should be enough to keep a good stable voltage. The fuel quantity wires came with the speedhut gauge and were a pretty good looking harness, but came up a little short at the end. I had to extend it.
Next was to install the electric fan relay. I got a Derale performance fan controller Part # 16759. It has the little pencil type probe. If I had known they offer a pipe threaded type probe, I would have welded in an extra bung in the radiator. Too late now. I can always get the other probe later, it just plugs into the same harness. I had a Derale in Cam's S14 and it had a melt down and shorted out. They seem to have made some improvements and now the relay is a plug in type
. Also wiring is a little different.
I mounted it up front because I wanted to keep the wires as short as possible. This seemed the logical place.
Wiring was a piece of cake. They also had a manual override circuit. This would bypass temp sensor or could be used if air-conditioning is turned on, but I figured I would be OK without.
The controller had a little adjustment screw for when the fan would kick on and off. CW for higher, CCW for lower.
I turned the power on and placed temp sensor in a cup of hot water with a thermometer. I added hot water and adjusted the screw to get the controller to switch on and off at the right temp.
I ended up at about 175 it kicks on and shuts off at about 165. Good place to start.
The probe inserted tightly between the cooling fins on the radiator.
That's about it for up here. I am taking Betzy on her first road trip this week (on a trailer). She is going to get an exhaust system and a roll bar installed. I need to get her ready...
Gord
