About the sub...
I actually chatted with a Crutchfield support person called Greg and here is what he said (regarding my 8 speaker system):
Door speakers are 2-ohm. He recommended I get the Infinity Reference 6032si. I intend to get 2 sets of these for the front and rear doors.
For the center channel (on the dash) - the speaker size is 3" but he says if it's working I shouldn't mess with it as that size is hard to find and they are only sold in pairs (we only have one).
I won't be touching the tweeters just yet. I just want some more bass.
Now, as for the subwoofer he said:
06/14/2010 03:36:29PM Agent (Greg.): "There is some custom work involved. First off, you need to drill new screw holes for the new sub in the rear deck. We also need to find a sub that matches the impedance of the factory sub. Then for the front door tweeters, there needs to be brackets made in order for the new tweeters to sit in that factory location."
06/14/2010 03:48:42PM Agent (Greg.): "As far as the subwoofer in the back goes, your best bet is going to be the Alpine SWS-1023D which has that dual 2 ohm design that we need:"
06/14/2010 03:48:49PM Agent (Greg.): "
http://www.crutchfield.com/cgi-bin/Prod ... 500SWS1023"
06/14/2010 03:49:21PM Ilya: "Do you think that will fit in the stock enclosure?"
06/14/2010 03:49:31PM Ilya: "I'm thinkin real estate is limited"
06/14/2010 03:51:59PM Agent (Greg.): "Actually, there is 8" of depth to work with plus 9.6" of cutout diameter. So that Alpine will indeed fit."
06/14/2010 03:52:18PM Ilya: "Awesome"
06/14/2010 03:52:47PM Ilya: "And I won't need an extra amp to run it? I read somewhere that one guy had to put an amp inbetween the stock amp and the after market sub because the sub sounded like crap without the added amp. Is that because he didn't match impedence?"
06/14/2010 03:57:07PM Ilya: "And is there anything else I need for this swap? Or just speaker wire?"
06/14/2010 03:57:38PM Agent (Greg.): "Exactly. You can still use the factory Bose amp. You really don't have to swap anything. You can use the factory wires. You do have to cut the factory connectors off and hardwire directly to the speakers and sub but nothing else has to be done."
06/14/2010 03:58:42PM Ilya: "Suhweet."
06/14/2010 03:58:54PM Ilya: "So the only thing left is to just figure out the mounting? Correct?"
06/14/2010 03:59:32PM Agent (Greg.): "That's about it actually."
06/14/2010 03:59:42PM Ilya: "Alright. Awesome."
06/14/2010 04:00:29PM Ilya: "For under $300, that's actually quite good. Thank you for your help."
