2008 G35xS Cluster Issue
Emz016
Car: 2008 G35xS High Tech
Hey guys,
I'm new to the forum and I have tried searching for an answer for this but nothing has come up. My battery recently died and when I boosted it, the tachometer needle points straight down. It moves when I drive but it does not show the correct rpm. I am wondering if there is a test or calibration that I can do to get the needle back to return back to its normal position. The speedometer, fuel and temp gauge still work properly. Any advice will be amazing!! Thanks!
Q451990
:welcome: to NICO!
The first thing I would try is pulling the cluster and manually moving it back to the correct resting position...
Check out the factory service manual at http://www.infinitiservicemanual.com for help accessing it.
Good luck!
Heath
audtatious
Yeah, that's a weird one. Go through the FSM and let us know if you find the problem.
