versahatch831 wrote:Trade it in!!! My Versa had similar problems. It Hesitated starting and the RPMs dropped lower than normal at a light. I am truly disappointed, the car has 29,000 miles!!! The dealer cannot duplicate the problem so they wont attempt to correct the problem. At this rate I do not think it will get to the miles that my 1990 Toyota Previa is at (295,000) and still going strong. Moral of this story is BUY A TOYOTA!! i regret not doing so.
This type of response is not acceptable. Go buy your Toyota and bask in all that is Barack Obama. I've made a lengthy post regarding these USELESS types of responses in my "Reliability Revisited" post. Please read.
Back to your legitimate question;
The previous posts suggesting the fuel pump are on target. I am surprised there are no stored codes... is the engine light still on? Next time it comes on, bring it to your mechanic of choice and ask him/her what codes are being generated.
The problem may also be as simple as water in the fuel tank. The season is right, and as I mentioned on another thread, I has some water in my tank that was causing the engine to fail to start. This actually happened on another vehicle of mine around this time of year. The ethanol used in fuels today can attract moisture, much in the way brake fluid does. Something to try; buy two bottles of "STP Gas Treatment," it can be found at Wal-Mart or any auto parts store. This particular treatment contains isopropyl alcohol, which will help absorb the water in your tank. Pour in both bottles on a full tank and drive around until you have about a quarter of a tank left, then refill with a good brand-name fuel. I would take it in for service anyway, but heck, this might fix it!
