JMPpath »
https://forums.nicoclub.com/jmppath-u236267.html
Mon May 19, 2014 4:26 pm
I have a 2006 Pathfinder with ~54K miles on it. Recently the SES light came on and the code pulled was P2A00. OBD2 data scanning showed A/F bank 1 sensor 1 reading of ~0.3V and not changing much. If I raise the RPM to 3-4K range for a few seconds then release the petal completely, it raises the reading to ~0.8V for a short time before returning to ~0.3V. Under the same conditions A/F bank 2 sensor 2 reads ~0.61V rising to ~ 1.3V when rev'd and released, so while it seams that the sensors are doing something, they are clearly not reading the same. I followed all of the code resolution steps in the FSM but I found no problems, so per the FSM I replaced the A/F bank 1 sensor 1 with a new Bosch direct fit sensor. Unfortunately this produced no change in the readings, even after driving the vehicle ~110 stressful highway miles over a mountain pass. I then swapped the old "bad" sensor into the bank 2 sensor 1 slot and what do you know, it reads fine in that slot. I checked the harness for problems the best I could according to the FSM and found nothing so I'm not sure what else is left except the ECM. This is very expensive and so I'd like to be sure before I do this any help would be greatly appreciated.
