werewolftigermonkey wrote:. Battery is getting a little weak,
How do you know that without testing it?
werewolftigermonkey wrote:I am seeing a strange issue with my drivers side headlight, a slight flickering,(not completely off )but bright/dim only when moving, when idle,it stops. !
Did you try swapping bulbs?
.. do you think it could be the battery, or, is this the bulb or the ballast? From doing a little digging it looks like I have my work cut out for me either way, just hoping someone has seen / resolved this and can point me in the right direction before I get started.
Any advice would be greatly appreciated!
If your battery is more than three or four years old it probably needs replacement
Test the cells with a battery hydrometer
If replacing the bulb doesn't cure the flickering it could be a bad connection or the ballast.
Good luck
Telcoman
