tarascarlet, make sure that your Infiniti dealer puts
EVERYTHING in writing - and keep a copy of the paperwork.
Wiggler wrote:This one dude on one of my recent threads is using Shell Rotella 15W-40 on his 2002...says he doesn't have issues anymore and hasn't seen a significant drop in mileage...weird, becasue that oil is primarily for big diesel engines...maybe you might look into it...
Under identical conditions, 15W-40 is thicker than the 5W-30 or 10W-30 commonly used - which helps to reduce oil consumption somewhat.
Although it's way outside the manufacturer's recommendations, my old Mitsubishi oil-burner likes 20W-50 - Goes MUCH farther on a quart than 10W-30 does! Yeh, it pours like molasses in the winter, but whatever...
Another "trick" for reducing oil consumption is to use single-weight oil (i.e., SAE 30), instead of the customary multi-weight.
None of these things are recommended for engines still under warranty, but if you've got nothing else to lose...
