Daniel G »
https://forums.nicoclub.com/daniel-g-u177279.html
Mon Jan 17, 2011 8:48 am
Hi Chris,
Sorry to hear that the reprogramming instructions didn't work. That is actually the first time that I've seen those instructions and was never aware that you could program a key fob without going to the dealership and paying their hefty prices. I'll have to save those for a future time when I may need to program a new fob!
I have a suggestion that may help fix your issue. When was the last time your car battery was replaced, if ever? I too was having a similar issue to yours about ~1 year ago. My key fob began loosing its signal strength and then completely stopped worked after a few weeks. I, like you, tried to replace the battery inside the key fob to no avail. I took my G35 into my dealership and let them diagnosis the issue, where they found that the vehicle battery was loosing its power, thus causing the system that controls the key fob to loose its signal strength and then completely stop working. I had to replace my car battery, it cost around ~$110 with free installation at my dealership.
If you know how to test your car battery, then give it a go! Or, if you don't, bring it into some mechanic shop and they will usually do the battery test for free. Best of luck with your situation. Hope it works out!
DG
