2004 Quest 35.SL - Passenger window won't stay closed
A forum for the Nissan Quest... minivan lovers unite!
jsi.miles
Car: 2004 Quest 3.5SL
I've got a bazaar one for you guys.
2004 Quest 3.5SL
Power windows work fine. EXCEPT, when closing the passenger window, it closes all the way and then immediately opens back up about 3-4 inches. Every time!
The work-around is to close the window tiny bits at a time until it's closed all the way.
Or, to close it from the drivers side, and then while holding the power window "lever/button" in the close (or physically up) position press the "window lock" button down. Releasing either buttons/lever's after this keeps the window closed.
Anyone else experience this?
Thoughts?
Jenamenifer
Car: 2004 Nissan Quest
2006 Nissan Altima
Mine is like that too. I think that's just the way it's designed to work
itinifni
Car: 2006 Quest SE Special Edition.
Mine does this as well, I found that by holding the switch in the up position rather than using the auto up, it will stay. release the master switch after window is stopped, in full up position. Works for me. I was stumped about this all last summer.
Switch Doctor
Car: 87 Saab SPG
There is a reset procedure you can do to fix it. I have see many different options so you may want to do your research. Here is a video that explains and guides you on how to fix the issue. http://www.youtube.com/watch?v=d6UvdbJ3nFk
Return to “Quest Forum”
