DeanM45 »
https://forums.nicoclub.com/deanm45-u203567.html
Sun Apr 06, 2014 6:28 pm
Hello everyone! I have a 2006 M45 with lotsomods and have been messing with cars for quite some time.
Recently a friend's 04 Q45 starting running poorly so he dropped it off at my house and through doing some leakdown tests, cooling system pressure, compression tests determined that both headgaskets are blown. Left between 3 and 5, right 2 to coolant. No coolant in oil. Upper radiator neck cracked -- maybe due to headgasket or maybe it caused the headgasket failure. I know the heads may be warped but I'm pulling her apart to check everything as I have time to work on her.
I know what a pain the M is to work on for header work (made a set of headers for her with the snaking around the steering shaft and a bunch of other crap)--and hopefully the Q is not as bad. I have the front of the motor off down to the chain cover, and the top of the motor off down to the heads.
Can the heads be removed and re-installed with the motor in the car or does the motor HAVE to come out? Without a lift it is simply easier for me to leave the shortblock in the car, if possible. Plus if he decides to let me buy the car I will just build a motor and do a swap down the road. The "good" cylinders are showing 10-15% leakdown (cold, no oil on cylinder walls) so I am confident that the short block is "OK" for now.
Any help would be appreicated.
Thanks!
