suzeqbee wrote:2004 Maxima with 135,000 miles. At 60,000 miles had to have Transmission Control Valve Assembly replaced when car would down shift hard at approx 20 mph.. It is happening again at 135,000 miles - estimated cost is +/- $1,600. The first time was under warranty - now it is out of my pocket. Has anyone had any experience with Transmission failures. How long should dealership warranty the initial repair.
Probably no warranty once the initial warranty has expired. However IF YOU PAY FOR A REPAIR the dealer will normally warranty it for life. Check with the dealer about the warranty before you have it done. You may want to consider a reputable transmission repair shop.
