dcarveriii »
https://forums.nicoclub.com/dcarveriii-u190196.html
Sat Sep 03, 2011 10:53 pm
1. My 04 M45 does not honk when I press the lock button. I have gone to settings in the display and checked for the lights to flash and the horn to honk and also held down the lock and unlock buttons on the remote but it still does not work. The horn does work when I press the button on the steering wheel. There is an aftermarket DEI alarm sticker on my fuse panel so I'm not sure if this would have something to do with it. All I have is the factory remote, nothing aftermarket.
2. None of my radio buttons work, Am/Fm, sat, cd, volume, nothing. They also do not light up at night when the interior lights are on. If I use the voice system and say radio on, the radio screen shows up, but the stations are blank and nothing works. No sound at all comes out of the speakers, including when GPS is on. I went into diagnosis mode and the audio amp and center control unit were both yellow. It seems to me that one of them may be a problem because it says they are not communicating with each other. The Infiniti dealer told me it was the audio amp but it doesn't make sense to me that none of the audio buttons would work just due to the amp. Any suggestions?
3. My cruise control does not work. I do have a flat tire warning that I believe is due to a bad tpms sensor. I just put brand new tires on the car and there are no issues with my tire pressure. My car does have the laser cruise. The cruise button works and the light comes on and beeps but it will not lock the speed in. Is this only due to the flat tire warning?
Thanks guys.
