pixelmxr wrote:
thanks telcoman...
I reviewed that once before, will give it a closer read today.
spoke with the sales rep at carmax.. WHAT A LAUGH I GOT. they ONLY want $$$$, sad to say. I got blown off when I asked about bleeding the air out, got ignored when I said, I will let you install the old thermostat, you sold it to me and got ignored when I asked if there were any other tests that could be run. He never spoke about gases in the coolant, never spoke about testing or flushing the radiator, he only wanted to talk about the $700 bill to to buy/throw parts at the problem. I will NEVER go to carmax for a repair again. NEVER!!!
pixelmxr
Review page CO 6
OVERHEATING CAUSE ANALYSIS
PFP:00012
Troubleshooting Chart
ABS0001H
Symptom Check items
Cooling sys-
tem parts
malfunction
Poor heat transfer
Water pump malfunction Worn or loose drive belt
Thermostat stuck closed —
Damaged fins
Dust contamination or
paper clogging
Physical damage
Clogged radiator cooling
tube
Excess foreign material
(rust, dirt, sand, etc.)
Reduced air flow
Cooling fan does not oper-
ate
Fan assembly —
High resistance to fan rota-
tion
Damaged fan blades
Damaged radiator shroud — — —
Improper engine coolant
mixture ratio
Poor engine coolant quality — Engine coolant viscosity —
Insufficient engine coolant
Engine coolant leaks
Cooling hose
Loose clamp
Cracked hose
Water pump Poor sealing
Radiator cap
Loose
Poor sealing
Radiator
O-ring for damage, deterio-
ration or improper fitting
Cracked radiator tank
Cracked radiator core
Reservoir tank Cracked reservoir tank
Overflowing reservoir tank
Exhaust gas leaks into
cooling system
Cylinder head deterioration
Cylinder head gasket dete-
rioration
Could be something as simple as a defective radiator cap or some of the items mentioned above.
If the simple items are not the root cause then you may be better off letting a dealer have a look at it.
One of my first major purchases after I first bought my previous 06 G35 was the paper version of the FSM.
A portion of my automotive library
The $300 cost of those manuals is easily amortized over a period of years either by doing easy repairs yourself or having the ability to speak intelligently to both service advisors and the Infiniti mechanic that will be working on your vehicle.
Although the on line FSM will help there is nothing like having the paper volumes that have loads of information easily missed when looking at the PDF on line. It is also much easier to find what you are looking for as well as using post it stickies on various pages.
Once they realize that you are aware of what the diagnosis entails you are less likely to get ripped off.
I learned a valuable lesson years ago in allowing cheaper independent shops do work on my vehicles.
Some of them either don't know what they are doing or they use cheap aftermarket poor quality parts in an attempt to keep costs down.
I have never let anyone but the dealer touch any of my Infinit's and the wife only trusts her Altima at the Nissan dealer.
A week of factory automotive training can cost $10k when you include the training, salary, meals, hotel, rental car, etc.
I'd rather pay the $130/hr labor rate and have the job done right the first time rather than let some a hole just replace parts in the hope he'll stumble upon the fix..
If needed I get the use of a loaner as well as my vehicle being returned cleaner both inside and out than when I dropped it off.
Good luck
Telcoman
