Discuss topics related to the QR series engine.
2003 Sentra Se-R Spec V build help
Postby jlfisher360 » Tue Mar 09, 2010 2:23 pm
I just purchased this car last week and I have been doing some research on it like what mods to do, etc. So far I've found out that removing the pre-cat is something I need to do first if I want to save my engine and that the engine internals (valve springs, camshafts) cannot handle being pushed hard and high HP. So here is the list of mods I plan on doing. Please comment if you see a part that is bad quality or not worth the moeny. (The reason for me listing so many Nismo parts is I have a friend that is hooking me up with them.)
Nismo Header w/o Pre-Cat
Nismo Cold Air Intake (maybe JWT POP charger)
Nismo Cat-Back Exhuast
Nismo Valve Springs (Maybe JWT?)
Nismo Camshafts
Nismo Front Strut Tower Brace
Nismo Lower Tie Bar
Nismo Rubber Bushing Kit
Nismo Shock/Spring Kit
Nismo Front Sway Bar
Nismo Brake Pads
JWT Pressure Plate & Disc
JWT Flywheel
Nismo Short Throw Shifter
Nismo Grounding Kit
STILLEN QR-PRO Engine Management
jlfisher360
Car: 2003 Nissan Sentra Se-R Spec V
Postby nametakennow » Sat Mar 13, 2010 5:18 am
NISMO parts are very expensive for what you get. Check other brands.
What are your plans for this car? What do you intend on doing with it? That should determine what mods you do.
'06 MINI Cooper S - Chili Red/White, stock
Sold - '01 Sentra SE (SR20DE) w/pp (VLSD, FSTB), a few mods
Sentra Table of Contents *Read it BEFORE posting!*
Get your Nissan/Infiniti's FSM here.
Need parts? Look here!
NEW QR25 forum
nametakennow
Car: '06 MINI Cooper S
Re: 2003 Sentra Se-R Spec V build help
Postby spec_v03 » Thu Apr 29, 2010 9:50 pm
QR Pro is a waste of money if you ask me. I'd just tune with an Apex'i SAFC II or NEO. Maybe use a wideband too if you track it. Also, JWT S1 cams are the same cut as Nismo, and cheaper, and also very good quality. And good luck finding Nismo parts, most for the b15 are discontinued, so youre limited to buying them used.
spec_v03
Car: 1991 Nissan Sentra SE-R
Return to QR Series
