Did you ensure you mated the torque converter and transmission back up properly??5implejack wrote:update: unfortunately i may have to give up on this. currently starts right up and runs makes a very mild clunking/knocking noise. main issue however is that it wont move at all. ive let it run in park for a while, checked the atf, topped it off but refuses make any effort to move. just sits in neutral and revs.
That's the first thing that came to my mind. I've never done it but I've heard lots of cases of it being done. Neighbor of mine who does a ton of side work was talking about a guy who did it 2 or 3 times on the same truck. Used extra long bolts because the engine and the transmission wouldn't meet.Blindaviator wrote:Did you ensure you mated the torque converter and transmission back up properly??5implejack wrote:update: unfortunately i may have to give up on this. currently starts right up and runs makes a very mild clunking/knocking noise. main issue however is that it wont move at all. ive let it run in park for a while, checked the atf, topped it off but refuses make any effort to move. just sits in neutral and revs.
I had a car MANY years ago that did the exact same thing (was one of the first cars I ever pulled the transmission out of when I was like 15 yo and it was a learning experience.) After I pulled the transmission for repairs and put it back in it would act like it wanted to move but just revd in every gear. Turns out I had done a foolish thing, when I mated the torque converter to the front of the transmission I didn't line up the pump notches quite right. When I started the engine it shattered the pump gear in the front of the trans. I had to pull it back apart and remove the front pump to replace it. After that it ran and engaged just fine.
If they were aligned improperly the first time and the pump was damaged then reseating it won't work... You will likely have to remove the pump and disassemble it to see if the gearing is damaged... That is what I had to do when I messed up mine years ago to find the damage...5implejack wrote: ↑Mon Jul 10, 2017 8:30 pmtried seating the torque converter again still nothing. everything lined up and bolted up no problem i must have messed something up last time i put it together or something.
