update: unfortunately i may have to give up on this. currently starts right up and runs makes a very mild clunking/knocking noise. main issue however is that it wont move at all. ive let it run in park for a while, checked the atf, topped it off but refuses make any effort to move. just sits in neutral and revs.
also shifter linkage is moving and the rpm drops/increases like its going into gear but it doesnt seem to actually shift. now its also throwing the crankcase sensor (p0335) as well as the 1065.
cant really spend any more money on it at the moment so might have to throw in the towel or at least hold off. if i find the funds in the near future may be looking into some other motor to swap in.
From what i found so far to make a 01 motor run in a 03 swap the harness/ecu unfortunately didnt have A harness from a basic search i thought the motors were the same. they are not. cams gears, flywheel, sensors and intake/tb are all different. so theres some probably not useful information gained from this whole en devour
thank you guys for all the help learned alot on this POS.
maybe ill swap something stupid into it who knows
