Not 100% sure on this, but isn't the fuel pump in the gas tank?Definitely not a DIY job if it is.Can someone verify?nametakennow wrote:No relearn required for the fuel pump. Should be plug and play.
Sure. Hooking up a fuel pressure gauge for testing is gonna be difficult unless you have the appropriate equipment. I have seen many fuel pressure regulators go bad in sentras.jhuman wrote:hey im having some starting trouble after my car is warmed up, it will just keep cranking when i try to start the car the first time so I have to take the key out of the ignition and crank it again for it to start properly could this be due to a faulty fuel pressure regulator?
