crazyboy3012 »
https://forums.nicoclub.com/crazyboy3012-u72903.html
Tue Mar 03, 2015 11:29 am
2003 Infiniti G35 sedan. 130K miles (US Car). Coolant flush and refill in 2011 oct . Oil changed every 3 months or 3000 miles whatever came first. Used Pennzoil @ the the local lube center. Still running on original plugs.
Ok !!! Keeping my fingers crossed...but here are the details.
On sunday evening I went to the automatic car was and got the car washed. On the drive back home i noticed the temp gauge increase from the mid level (which is where i have always seen it over the last 7 yrs) towards the higher end. I turned of the in cabin heating and slowed the car...I was very close to my house so I decide to drive instead of pulling over...the temp indicator never went all the way up to "H"
After few hrs, i opened the hood and noticed that the coolant level in the overflow box was below min. I had no coolant in stock...so on monday morning i went to walmart and got Prestone 50/50 coolant and filled up the overflow tank to the max level. I proceeded to work which is about 15 mins drive on the freeway and i noticed that the car did not overheat...the temp indicator was right around the mid range between "H" and "C". One thing I did notice is that when I turned on the heat in the cabin, it blew ambient air.
On my way back home yesterday the car was running allright until a couple of minutes before i entered my driveway the temp indicator started rising up mid way between mid and "H".
I stopped at the driveway, let the car cool. Looked online for possible problems. Found a thread that explained how to bleed the cooling system so this morning I opened the radiator cap and noticed that the coolant was not all the way to the top...so I added about 2 cups of coolant that brought it up to the cap level...the coolant at the overflow tank is at the max level. I turned on the car and let it idle for 10 mins...when the car warmed up I revd it to 3000 rpm for 10 s about 2-3 times and then turned on the heat and to my amazement the in cabin heating worked like a charm. I drove around the neighborhood for about 10 mins and i noticed that the temp gauge was steady at the mid level. the heating worked fine. Also i could hear the fluid (water) flowing.
Also, checked the oil level yesterday and today and the level seems ok and the oil is not mucky..i.e i don't think the oil and coolant have come in contact...hope not. One think i did notice was a slight white fumes from the tail pipe...i know thats not good news.
Not sure what the problem is. I Called the infiniti dealership and they quoted me 109$ for a diagnostic test. I have just given my car at the dealership and received a courtesy car.
My wife is 39 weeks pregnant and a baby is due any moment...I have to take her for her 39th week chk up this afternoon. With all this stress I took a day off work..... I just cannot cope with an unreliable car at the moment...for my piece of mind, i gave it at the dealership for diagnostic and got a courtesy car in return that way i have a mode of transport.
What do you guys think?
1. leak in the cooling system
2. water pump
3. thermostat
4. head gasket (hope not)
any other possibilities?
Appreciate your feedback and advice as always.
Once I hear from the dealership I'll let you guys know what they found out during the diagnostics.
Thanks in advance.
crazyboy3012 on Tue Mar 03, 2015 12:09 pm, edited 1 time in total.
