2003 Infiniti G35, 4D sedan, 135 k miles
Last few weeks my G is is giving me intermittent starting problems. I have a brand new battery and the G is cranking well so I think it is the ignition switch. I came across the post below through google and my G does exactly the same
http://g35driver.com/forums/g35-sedan-v ... e-out.html
I opened up the housing below the steering and the nearby panels to get access however, i could not quiet figure out how the switch could be dismantled. I know it is connected to a harness which can be removed but I also understand that there is a screw that needs to be removed. How do i access this screw? Any tips? ideas?
Thank you in advance !
