2003 Infiniti G35/2001 Nissan Skyline-Code P1130
v35skyliner
Car: 2001 Nissan Skyline V35 250GT
I want everyone to know that if you have one of these cars or similar I have found a lot of people asking what can throw a code P1130. Believe it or not, I found that the engine control fuse in the larger fuse relay box under the battery void cover can throw this code if it gets blown. The symptoms will be a check engine light and loss of power over 3500 rpms on top of the P1130 code. I thought everyone might want to know because it can lead to a lot of frustration. (The fuse mentioned is second one from the bottom on the ride side of the fuse columns. It is a 10 amp fuse.) Hopefully this is helpful.
Rogue One
Car: 2011 Nissan Rogue SL
2012 Nissan Rogue SL
2012 Honda CR-V LX
2022 Honda Pilot Special Edition
Thanks for the heads up! :dblthumb: Just a thought, could you post a picture of the fuse in question so that it's easier to identify for others that may have this issue?
