If you have a Nissan truck or SUV including Infiniti.. and had these codes come up P1701, P1702, P1703, P1704, P1705, P1754, P1759, P1764, P1769, P1774 you might be having a valve body issue
Heres a step by step in changing the valve body..
these codes seem to be a really bad issue with Nissan.. please fallow Diagnosis cart..
i checked everything so its in the TCM.. so out it comes..
if you look at the new valve body you'll see what bolts need to be loosen.. make sure you let it drain completely.. when coming down with it.. its going to hang from the black plug.. just un-clip the green plug and then remove valve body..
after that go to the black plug on the transmission and remove the retainer ring and with pliers wiggle it and push down..
done with removal, on the new valve body there some brackets missing your going to have too take it off the old one..
now its time to put it back in.. it will take 8qts if you let it drain completely
This repair cost was $2,000.. in the dealer is $2,300.. prices very by locations..
if you do it yourself it will save you around 600 to 800 of dollars.. just make sure everything you do is at your own risk..
if there any way i can help NICO members please feel free to send me a PM or e-mail..
