harpethriver »
https://forums.nicoclub.com/harpethriver-u170010.html
Mon Feb 13, 2012 9:45 am
I've had this 2002 Xterra for a few months and after replacing the timing belt, valve cover gaskets, rear main seal, plugs, all the belts and cleaning the engine it suddenly started throwing fault codes PO132 (O2 sensor) and PO328 (knock sensor). Each time I reset the codes they would throw within about 35 miles. It has only had Shell premium fuel run through it-on it's 3rd tank. I let the fuel level run down til the low fuel light came on each time before filling. I thought it strange that both codes would throw at the same time, and after a little research found a bulletin that essentially said the two share a common ground, so we wired a common ground for the two and replaced the O2 sensor. This time I went through about 4-5 drive cycles and over 50 miles, and the codes threw again. I can't believe the 02 and knock sensor both coincidentally fail at the same time. I have read that using an aftermarket timing belt, which may have not been sized like OEM could throw the codes. Obviously the knock sensor is a time consuming fix, and I'd like to avoid that. I've read where this is not an uncommon problem, but I can't seem to find anyone who says there's a definitive fix. I'd like to keep this thing for a while, so I drove it a bunch before putting a lot of money in it, including new rubber all the way around, and after I think I've got it dependable and running right, with all the required maintenances updated, this fault codes issue pops up. Anybody got any ideas here? Thanks for your help!
