Long story, but I'll try to break it up into its basic elements...
- Bought non-cranking car for $500. Diagnosed as ECU, considering previous owner had checked for compression, replaced plugs & fuel pump.
- Before exchanging ECUs, I cleaned the throttle body and Idle Air Control valve. The spring popped out of the IAC vavle, and I'm not 100% sure I put it back in the right way, but it starts working later, so I'm guessing I did??
- Eventually got replacement ECU, and car crunk right up. She was just purring in my yard!!
- Only problem was that there was white smoke coming out of the tail pipe and the oil filler tube.
- Eventually got some Bars Leaks "Head Gasket Fix" #1111, because I've heard great things about this stuff. Initially, I only put a couple table spoons straight into the radiator. But it
appeared full, so I put the rest of the 24 oz. bottle into the reservoir. Smoke had stopped almost instantly. Drove around for at least an hour with heat on high. Then I realized that the reservoir was clogged or something, because the fluids hadn't moved in there. I checked the radiator, and it wasn't full!! So, I took the reservoir out, poured it into the original bottle it came in, then poured just less than half into the radiator
for good measure!
The radiator was still not topped off, so I put some 50/50 in there until it was, then topped off the reservoir. Drove it around for another hour or so with heat on high.
- Everything was great until the next day. I decided I'd give it one more run from one end of town to the other end, which I needed to do anyway. Even replaced a 15amp "Blower Motor" fuse that was missing in the fuse box, and got the second fan to work by jiggling the switch around. Had the heat on high again. Didn't really dog it out like I did the day before. But TODAY, as I get two blocks away from my house, exactly as I'm thinking about how I didn't do the Idle Relearn Procedure, the cars idle starts to drop. And then after 5 - 10 seconds, the idle got to 500 then just died. Crunk right back up, then died. Crunk up one more time for the green light, then I made it to the stop sign. Died there. Crunk up the last time and I pulled into my yard, where it died.
- Pulled out the OBD2 scanner. No logged/historic faults (even tho, the Service Light has been on during all these drives??), but there were two pending faults --> P0134, P0154. I believe these are the pre-cat O2 sensors, "no activity detected". s***. I've never had an O2 sensor REALLY cause a problem before, so I figure the problem must be elsewhere.
- I cleaned out the PCV valve and the whole line. No help. Same instant stall at idle.
- It started to rain as I was putting my stuff up, so I figured I'd go try to drive it around with my foot on the gas everytime I braked. Plus, I already had the idle relearn procedure written out from when I replaced the ECU. Drove it around until normal operating temps, took it to a parking lot near me, then proceeded with the instructions. I tried it at least 10 times, and I could *never* get the MIL to blink. I think my problem might have been that I didn't release the pedal ALL the way, but I think it still should have blinked??
Anyway... I'm at a loss now. Also, I did check the spark plugs... and all four looked a tad dry if you ask me. So I'm guessing the engine is running lean for some reason or other.
I really don't think the IAC is my problem since I already cleaned it and it was running just fine. Ditto for the relearn procedure... I don't think that would make it stall at idle after it was running just fine for 60 or 70 miles.
Car runs great, so long as I keep my foot on the gas when braking... but the spark plugs show that the fuel/air mix might be a little lean. So, perhaps this is an EGR problem. Never cleaned EGR before, so looking for a writeup on this or any other advice. Don't know what else to do anymore, really.
