Sounds more like a key cylinder issue to me like you suggested. I had similar issues in my 02' PF when my battery went dead and lost Key programming and triggered a few NATS(anti-theft) codes. My car had similar symptoms, i believe i had no fuel or spark coming from ECM due to Key chip reader sensor not recognizing my keys but cant remember if it did indeed crank the engine or not. My next best guess would be a bad starter solenoid or starter altogether. Just my .02. Hope this helps.atraudes wrote:It's certainly worth a try! Check the FSM; it should have some info on testing its resistance or some such to verify it's not obviously bad while you're at it.
I just did some searching around, and based on this thread, the P0335 code may be a red herring that's a side effect of the no starting issue.
^^^I live in S.FL as well and i'm currently having similar starting issues with my 02' PF eventhough it only has 127k on it. I have a 2nd car so stopped driving my truck for awhile n it usually sits in my backyard for days at a time. I have a canal in my backyard and get a lot of humidity on the cars everyday over night. My truck has begun just clicking when i go to start her up and sometimes it takes 2,3 clicks while sometimes its taken up to 20x for it to start. I'm guessing the humidity has gotten to the contacts on my starter solenoid bcuz once the signal goes through, the starter turns over with full strength. I went online the other day and looked into the starter solenoid on the Advance AP site and its about $107 when a complete REMANFD starter WITH new solenoid sells for around $95. Lately i've been driving the truck more often and its been cranking up much better sometimes on the 1st or 2nd try so i'm guessing the electrical contacts have been doing their job correctly or got "cleaned up". Still, i've been a bit busy but will eventually take off the oem starter, open it up, and sand down or clean the internal contacts since im pretty sure thats whats causing my issue since it didnt do this before when i used to drive her daily. Hope this helps out with any questions u have on this issue.wildpig wrote:Looks like there are 2 crankshaft position sensors (named REF and POS in the service manual) in 02 pathy. I disconnected the easiest one I could get to underneath the car near the oil pan (POS) and the car did crank but it never start. Connected it back and car started again just fine. So I don't think it's the crankshaft position sensor and that p0335 might have been a red herring.
The weather in FL is now back to nice 70's again so I might have no choice but to wait it out til whenever this happen again maybe next winter? or whenever.. hopefully never happen again...
So it might still be the neutral position sensor that's sending the wrong signal or possibly still be a bad starter?
Anyone can name anything else that can cause the car not to crank or make any starting noise at all (like complete silence) with good battery and all interior accessory powered up fine?
302LVR wrote:^^^I live in S.FL as well and i'm currently having similar starting issues with my 02' PF eventhough it only has 127k on it. I have a 2nd car so stopped driving my truck for awhile n it usually sits in my backyard for days at a time. I have a canal in my backyard and get a lot of humidity on the cars everyday over night. My truck has begun just clicking when i go to start her up and sometimes it takes 2,3 clicks while sometimes its taken up to 20x for it to start. I'm guessing the humidity has gotten to the contacts on my starter solenoid bcuz once the signal goes through, the starter turns over with full strength. I went online the other day and looked into the starter solenoid on the Advance AP site and its about $107 when a complete REMANFD starter WITH new solenoid sells for around $95. Lately i've been driving the truck more often and its been cranking up much better sometimes on the 1st or 2nd try so i'm guessing the electrical contacts have been doing their job correctly or got "cleaned up". Still, i've been a bit busy but will eventually take off the oem starter, open it up, and sand down or clean the internal contacts since im pretty sure thats whats causing my issue since it didnt do this before when i used to drive her daily. Hope this helps out with any questions u have on this issue.wildpig wrote:Looks like there are 2 crankshaft position sensors (named REF and POS in the service manual) in 02 pathy. I disconnected the easiest one I could get to underneath the car near the oil pan (POS) and the car did crank but it never start. Connected it back and car started again just fine. So I don't think it's the crankshaft position sensor and that p0335 might have been a red herring.
